Jwen556
- 3
I have 2 walls, 3 springs, and two masses. The masses and springs are not necessarily similar to the other(s).
They are connected in a configuration: Wall-Spring1-Mass1-Spring2-Mass2-Spring3-Wall.
I need to find equation for both masses, given that not all springs are in equilibrium when the system is set into motion.
Assume that for this system, there is one scenario in which the system is in its equilibrium state. In this state, x_1 and x_2 (defined below) are 0.
Springs constants: k_1, k_2, k_3
Masses: m_1, m_2
Displacement of mass 1 from equilibrium: x_1
Displacement of mass 2 from equilibrium: x_2
F = -kx
U = 1/2 * kx^2
K = 1/2 * mv^2
E = U + K
dE/dt = 0 (closed system)
I first calculated the forces on each mass for a given position and found that
F_1 = -k_1 * x_1 - k_2 * (x_1 - x_2)
F_2 = -k_3 * x_2 - k_2 * (x_2 - x_1)
Also, E = 1/2(∑kx^2 + ∑mv^2)
(' denote derivative with respect to time)
and dE/dT = k_1*x_1*x_1' + k_3*x_2*x_2' + k_2*(x_1 - x_2)(x_1' - x_2') + m_1*x_1'*x_1'' + m_2*x_2'*x_2'' = 0
But I'm not sure what to do from here.
First, are my equations for force correct? The middle spring (#2) applies the force F=-kx to two objects and I have only ever dealt with springs fixed on one end so I'm not sure.
Also the dE/dT = 0 is a nonlinear differential equation and I have only ever dealt with linear differential equations so I don't know how to solve it.
Would this be better in Physics homework help? I posted here since it is homework for a DE course.
