timharvey027
- 2
I would like to invite your comments on three thought experiments. The first i suggest demonstrates that light cannot be either a stream of photons nor a wave. The second questions if light can also have momentum and the third asks why a theorectical truth is not observed.
Here we go, 1. Consider a small light source which is completley spherical. Light is emitted from it, imagine for a moment that light emitted is in straight lines almost like a million laser beams being emitted from a shepherical pin head. Now because the surface is spherical there will be a miniscular difference of a degree of the angle in which each light path is emitted. If this is refutted with the argument that light is emiitted at every angle from every point then this would mean that an infinate number of light paths and thus sources would exist ( not possible). So again because the surface from which the light is emitted is shepherical this means that to an observer a million miles away the appearance of light emiitted would be like a round pin head with a million spikes protruding from it, as you move further away from the source the distance between the spikes increases, meaning that to viewers further away those seeing othe space between the spikes and thus the source source would not be visble. More detail available if needed.
2. Imagine you are on a train bouncing a ping pong ball up and down on the table in front of you. It works.I agree that the movement of the ball will be seen differently from an observer on the platform from that on the train.
Suppose the that the bouncing ball is replaced by light traveling between two mirrors on the train representing the bat and the table top. My question is, does light have the momentum that the ping pong ball has when it leaves it's fist source. Do actual observations confirm that light will rebound to a pooint different from its emmission.
3. Imagine a set of four mirrors set within a square at 90% such that any light intoduced would reflect off of each mirror forming a square, in theory this light would continue to reflect. Further imagine that one of the mirrors is a two way mirror and that a laser beam is introduced firing at the next mirror, after some moments the two aspect of the mirror is converted back to a reflecting mirror. In theory the light beam should continue to reflect between the mirrors in a continuous square but it does not, why?
Sorry for the lack of detail i have tried to keep this short
