3D parametric vector plot question
In summary, there is a command in Mathematica called ParametricPlot3D that can plot a vector field in spherical coordinates as a function of a single parameter. The notation is ParametricPlot3D[{f_x, f_y, f_z}, {s, s_min, s_max}] and more details can be found in the documentation.
member 428835
Hi PF!
Given a vector field ##\vec f## in spherical coordinates as a function of a single parameter ##s##, shown here as
$$\vec f(s) = f_r(s) \hat r + f_\theta(s) \hat \theta + f_\phi(s) \hat\phi$$
where here subscripts do not denote partial derivatives, but instead are used to define components of ##f##, does anyone know the easiest way to plot this vector field?
I googled it but I didn't find anything too helpful (maybe I'm a bad googler).
Edit: I would also be happy with a 2-D image too, say the x-z or y-z plane.
Hi, in mathematica there is a command: ParametricPlot3D that you can use in order to plot the vector field with ##s## as parameter, the precise notation is
ParametricPlot3D[{##f_{x},f_{y},f_{z}##},{##s,s_{min},s_{max}##}]
where ## f_{x}(s),f_{y}(s),f_{z}(s) ## are the three components depending by ## s ## in the range ##[s_{min},s_{max}]##.
Details are in this documentation: http://reference.wolfram.com/language/ref/ParametricPlot3D.html
Ssnow
Likes member 428835
Ssnow
Thanks! No clue how I missed this!
Related to 3D parametric vector plot question
1. What is a 3D parametric vector plot?
A 3D parametric vector plot is a visual representation of a function in three-dimensional space, where the input parameters are represented by vectors and the output values are represented by points in space. It is commonly used in physics, engineering, and computer graphics to visualize mathematical models and systems.
2. How is a 3D parametric vector plot created?
A 3D parametric vector plot is created by defining a parametric function with three variables (x, y, and z) and specifying the range of values for each variable. The function is then evaluated at each point in the specified range, and the resulting points are connected by vectors to create a 3D plot.
3. What are the benefits of using a 3D parametric vector plot?
One of the main benefits of using a 3D parametric vector plot is that it allows for the visualization of complex mathematical models and systems in three-dimensional space. This can provide a better understanding of the relationships between variables and how they affect the output of the function.
4. What are some common applications of 3D parametric vector plots?
3D parametric vector plots are commonly used in physics to visualize forces and motion in three-dimensional space. They are also used in engineering to model and analyze systems such as fluid flow, electric fields, and stress distribution. Additionally, they are widely used in computer graphics to create 3D animations and simulations.
5. Are there any limitations to 3D parametric vector plots?
One limitation of 3D parametric vector plots is that they can become difficult to interpret when there are too many vectors and points, making the plot cluttered and confusing. Additionally, they may not accurately represent the true behavior of a system if the input parameters are not well-defined or if there are external factors that affect the system.
  • Atomic and Condensed Matter
  • Calculus
  • Differential Geometry
