3d printing neuron with membrane potential
In summary, the conversation discusses the possibility of 3D printing a neuronal structure with a different material than neurons that would work like a neuron with membrane potential. It is mentioned that 3D printing is not currently capable of such resolution and that neurons are dynamic and require the ability to change in response to their environment. The discussion also touches on the challenges of creating prosthetics that can interface with the nervous system, including the need for sensory feedback and the ability to interpret signals from the nervous system. It is noted that there has not been a prosthetic with artificial neurons that can generate a membrane potential through ionic diffusion. The conversation concludes with the question of how to generate an action potential on a synthetic membrane, to which it is suggested that
fredreload
250
Is it possible to 3d print a neuronal structure with a different material than neurons that would work just like a neuron with membrane potential?
Biology news on Phys.org
Neurons are micro-scale cells (in most axes). As far as I'm aware 3D printing is not capable of that sort of resolution. Further more neurons are dynamic, they have to be able to change in response to their environment. No only do they have to alter synaptic strength but be capable of metabolism, self repair, growth etcetera. A purely static object won't be "just like" a neuron.
Can't you get a material similar to neuron that is capable to transmit signal? I mean for a synthetic limb you wouldn't need self repair and growth if you get the right material. The brain plasticity can get a bit tricky but the brain eventually becomes static. The material does not need to behave like a cell, it just need to have a membrane potential for transferring ions.
P.S. What do you think Ryan?
Hmm, how else would you go about producing a structure like this?
Nerves themselves need to adapt on the basis of the signals they transmit. Prosthetics that try to interface with the nervous system do so in a variety of ways but mainly use electrodes to detect when the peripheral nerves are firing and processors to decode this and turn it into movement. There are various reasons as to why this hasn't led to a perfectly functioning prosthesis, from what I've read it's not just a problem of resolution (being able to interpret all the signals) or decoding (turning those signals into prosthetic movements) but also providing feedback. This paper reviews some of the models in which prosthetics can try to provide sensory feedback to the user so that A) they are not overburdened by having to visually control their prosthesis and B) have a healthier relationship with their prostheses:
http://www.ncbi.nlm.nih.gov/pubmed/26017599
Once they work out the senses, they still need to provide the sort of muscle contraction like this for the prosthesis. This got me worried as to if it would become a technical issue. But after all, the arm is just consisted of muscle, bone, nerve, sense of touch and pain. Once they get muscle contraction to work it should come pretty close to being a real limb.
There should be a working carbon nanotube synapse by now right? Most of it is in the thesis paper by 2011 and 2013.
To get pretty close to a real limb it not only has to be able to move in all the ways a human limb can but also provide sensory feedback and be able to interpret signals from the nervous system to such a high degree that dexterous movement is possible. All big challenges.
What paper are you talking about? A synapse is the junction between two nerve cells, making an artificial one doesn't immediately make good prosthetics possible. Better interfacing with the nervous system for both signal interpretation and feedback are important. It's also worth noting that in event of trauma nerve cells die off and retract. If your arm has been severed the nerves that did connect to your fingers don't just stay there waiting for a job to do. They die off. Persuading cells to regrow is an active area of research, though I'm not aware of any nerve guidance conduits being used in prosthetic research.
Well what I am thinking of is prosthetic with artificial neuron that is possible to generate a membrane potential. Once you get the artificial nerve working you can get a tie between the artificial nerve and the real nerve. It is just there hasn't been any prosthetic with artificial neurons made that uses membrane potential through ionic diffusion to get the signal across. The only material that I found on the net that can be structured to resemble a real neuron is carbon nanotube. Again I think you don't need a real living cell for membrane potential to work, a non living artificial neuron should be able to provide membrane potential just as well. Thanks again for the response
At a quick glance I haven't found anything that can transfer ions here in synthetic membranes. What do you think? And http://highered.mheducation.com/sites/0072495855/student_view0/chapter14/animation__the_nerve_impulse.html awesome animation
So my question is, how do you generate an action potential on a synthetic membrane?
Hmm, after further reading it seems you need some way to create an artificial transport system to maintain a charge difference, essentially an energy input(ex. ATP).
Related to 3d printing neuron with membrane potential
1. What is 3D printing of neurons with membrane potential?
3D printing of neurons with membrane potential is a process of creating three-dimensional models of nerve cells using a specialized printer. These models are designed to mimic the structure and function of real neurons, including the ability to generate and transmit electrical signals.
2. What materials are used in 3D printing neurons with membrane potential?
The materials used in 3D printing neurons with membrane potential vary depending on the specific printer and technique used. However, common materials include biocompatible polymers, hydrogels, and conductive materials such as graphene or silver nanoparticles.
3. What are the applications of 3D printing neurons with membrane potential?
3D printing neurons with membrane potential has several potential applications in neuroscience research and medicine. It can be used to better understand the structure and function of neurons, create models for drug testing and disease study, and even facilitate the development of neural prosthetics.
4. How accurate are 3D-printed neurons with membrane potential?
The accuracy of 3D-printed neurons with membrane potential depends on the resolution and precision of the printer used. With advanced techniques and high-quality materials, it is possible to create models that closely resemble real neurons in terms of size, shape, and electrical properties.
5. Can 3D-printed neurons with membrane potential be used for transplantation?
At this time, 3D-printed neurons with membrane potential are not developed enough to be used for transplantation in humans. However, there is ongoing research and experimentation in this area, with the goal of eventually being able to create functional neurons for therapeutic purposes.
  • Biology and Medical
16K
