MHB -4.3.1 find quadratic eq given 3 pts
  • Thread starter Thread starter karush
    Quadratic
To find the quadratic equation given the points (-3,0), (3,0), and (0,-4), the general form y = ax^2 + bx + c can be used. By substituting (0,-4) into the equation, it is determined that c = -4. The roots at x = -3 and x = 3 lead to the equation y = k(x-3)(x+3), and substituting x = 0 gives -9k = -4, resulting in k = 4/9. Thus, the quadratic equation is y = (4/9)(x-3)(x+3). This method effectively combines substitution and root analysis to derive the equation.
karush
MHB
how do you find the quadratic equation given (-3,0) (3,0) and (0,-4)
thus y=k(x-3)(x+3) for the zero's but how do you find k or any other better method of finding the equation
thanks much(Cool)
Mathematics news on Phys.org
This can be done by looking at the general form of a quadratic equation: [math]y=ax^2+bx+c[/math]. We need to solve for a,b and c in order to write our equation and we have three points so we can do this through substitution. First use (0,-4) for (x,y) and you get [math]-4=a(0)^2+b(0)+c[/math] which means that c=-4. Now use the other two points the same way and you will have to solve a two variable system of equations for a and b. Once you have a,b and c you have your answer.
Starting from y=k(x-3)(x+3) (which gives the value 0 when x = 3 or –3), all you need to do is to put x=0 to see that y = –9k when x=0. But you want y to be –4 when x=0. Therefore –9k = –4. So k = 4/9, and $y = \frac49(x-3)(x+3).$
Another way (if you have covered the Lagrange Interpolation Polynomial):
$y=0L_1+0L_2-4L_3=-4\dfrac{(x+3)(x-3)}{(0+3)(0-3)}=\dfrac{4}{9}(x+3)(x-3)$
no have not heard of it. looks valuable tho so will look it up thanks
$y = \dfrac{4}{9}(x-3)(x+3)$
ok I can't seem to write tikx to plot this
$\begin{tikzpicture}[scale=0.50]
%preamble \usepackage{pgfplots}
\begin{axis}[xmin=-3.5, xmax=3.5, ymin=-5, ymax=5, axis lines=middle, ticks=none]
\addplot[
draw = black, smooth, ultra thick,
domain=-4:4,
] {exp((4/9)*(x^2-9)}
foreach \x in {-3,3} { (axis cs:{\x},0) node[below left] {\x} };
\end{axis}
\end{tikzpicture}$
$$y = \dfrac{4}{9}(x-3)(x+3)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
