MHB 48.2.2.23 IVP and min valuew
  • Thread starter Thread starter karush
    Ivp
The discussion centers on solving the initial value problem for the differential equation y' = 2y² + xy² with the initial condition y(0) = 1. Participants clarify the integration process, noting a typo in the equation where the term x²/2 was incorrectly represented. The correct integration leads to the expression -1/y = (x²/2) + 2x - 1, with the constant of integration determined as -1. The final solution for y is expressed as y = -1/((x²/2) + 2x - 1) or equivalently y = -2/(x² + 4x - 2). The conversation emphasizes the importance of accuracy in mathematical notation and the integration process.
karush
MHB
\tiny{b.48.2.2.23}
Solve the initial value problem $y'=2y^2+xy^2,\quad y(0)=1$
find min value
$\begin{array}{ll}
\textit{separate variables}
&\dfrac{1}{y^{2}}\ dy=(2+x)\ dx\\ \\
\textit{integrate}
& -\dfrac{1}{y}=2x+\dfrac{x^2}{2}+C\\ \\
\textit{plug in $(0,1)$}
& -\dfrac{1}{1}=0+0+c \therefore c=-1\\ \\
\textit{the equations is}
& y=-1/(x/2+2x-1)+c\\ \\
y'=0 & \textit{returns } x=-2
\end{array}$
typos maybe:cool:
There is a typo where you have
$y= -1/(x/2+ 2x- 1)+ c$
You clearly intended "$x^2/2$". Also, having determined that the constant of integration was -1, where did that additional "c" come from?
here is the book answer
yeah your right about the $x^2$
karush said:
\tiny{b.48.2.2.23}
find min value
$\begin{array}{ll}
\textit{integrate}
\end{array}$
typos maybe:cool:
Every thing is good until that last equation!
Integrating gives
$-\frac{1}{y}= \frac{x^2}{2}+ 2x+ C$
an y(0)= 1 gives C= -1 so
$-\frac{1}{y}= \frac{x^2}{2}+ 2x- 1$.
Then solving for y (if you are asked to do so- I would consider the previous line a perfectly good solution)
$y= \frac{-1}{\frac{x^2}{2}+ 2x- 1}$
or, if you don't like a fraction in the denominator of afraction, multiply both numerator and denominator by 2:
$y= \frac{-2}{x^2+ 4x- 2}$
But, again, where did that "+c" in your last line come from?
