4th order Runge Kutta Matlab with 2 2nd order ode
In summary: F_X = @(t,X,Vx) Vx;F_Z = @(t,Z,Vz) Vz;F_Vx = @(t,X,Vx)(0.866*(sin(thete)-0.5774*(cos(thete))));F_Vz = @(t,Z,Vz)(0.866*(cos(thete)+0
noelll
Hi There!
MX''=Fn(sin θ - uCos θ )
MZ''=Fn(cos θ + uSin θ ) - Mg
Fn,M,θ,u is constant
fn/M = 0.866
M = 6000
θ = 30
u = 0.5774
i split my motion equation into 2 individual 1st ode,
X' = Vx
Z' = Vz
Vx'=[fn*(sin θ - uCos θ )]/M
Vz'={[fn(cos θ + uSin θ )]/M} - g
After trying many tutorials i still don't understand how to implement my motion equation into matlab,
i tried to do the following for Vz' motion but it seems wrong, my right hand side of the equation does not have t or y. please help !
clc; % Clears the screen
clear all;
h=0.1; % step size
thete=30;
g=9.81;
x = 0:h:3; % Calculates upto y(3)
y = zeros(1,length(x));
y(1) = 5; % initial condition
F_z = @(t,y) 0.866*(cos(thete)+0.5774*(sin(thete)))-g; % function
for i=1:(length(x)-1) % calculation loop
k_1 = F_z(x(i),y(i));
k_2 = F_z(x(i)+0.5*h,y(i)+0.5*h*k_1);
k_3 = F_z((x(i)+0.5*h),(y(i)+0.5*h*k_2));
k_4 = F_z((x(i)+h),(y(i)+k_3*h));
y(i+1) = y(i) + (1/6)*(k_1+2*k_2+2*k_3+k_4)*h; % main equation
end
hold on %Plot graph
plot(x,y,'+-', 'Linewidth', 1.5, 'color', 'blue')
xlabel('x')
ylabel('y')
legend('RK4')
Thank you
It shouldn't be too hard to find the analytical solution to the ODEs and compare to what you are calculating. Your RK algorithm appears correct.
Next time, please use code tags around your code to make it easier to read, eg,
[CODE="matlab"]
[/CODE]
gives
Matlab:
Hi thanks so much for your reply,
However my knowledge on MATLAB functions is still limited , base on my four 1st order ode
X' = Vx
Z' = Vz
Do I need to write a function for each ode? How do I write it?
Currently I only have one function which is
Matlab:
Please help
Thank you
DrClaude said:
The Matlab documentation available online is very good. For functions, see http://www.mathworks.com/help/matlab/ref/function.html
Hi thanks for your reply,
Matlab:
clear all;
thete=30;
g= 9.81;                                             %Constant
h=0.001;                                              % step size
tfinal = 3;
N=ceil(tfinal/h);                                      %ceil is round up
t(1) = 0;% initial condition
Vx(1)=0;%initial accleration
X(1)=0;
Vz(1)=0;
Z(1)=0;%initial velocity
F_X  = @(t,X,Vx) Vx;
F_Z  = @(t,Z,Vz) Vz;
F_Vz = @(t,Z,Vz)(0.866*(cos(thete)+0.5774*(sin(thete)))-g);for i=1:N-1;                                         % calculation loop
    %update time
    t(i+1)=t(i)+h;
    %update motions main equation
    k_1 = F_X (t(i)      ,X(i)          ,Vx(i));
    L_1 = F_Vx(t(i)      ,X(i)          ,Vx(i));
    k_2 = F_X (t(i)+0.5*h,X(i)+0.5*h*k_1,Vx(i)+0.5*h*L_1);
    L_2 = F_Vx(t(i)+0.5*h,X(i)+0.5*h*k_1,Vx(i)+0.5*h*L_1);
    k_3 = F_X (t(i)+0.5*h,X(i)+0.5*h*k_2,Vx(i)+0.5*h*L_2);
    L_3 = F_Vx(t(i)+0.5*h,X(i)+0.5*h*k_2,Vx(i)+0.5*h*L_2);
    k_4 = F_X (t(i)+h    ,X(i)+h    *k_3,Vx(i)+    h*L_3);
    L_4 = F_Vx(t(i)+h    ,X(i)+h    *k_3,Vx(i)+    h*L_3);
    k_11 = F_Z(t(i)      ,Z(i)          ,Vz(i));
    L_11 = F_Vz(t(i)     ,Z(i)          ,Vz(i));
    k_22 = F_Z(t(i)+0.5*h,Z(i)+0.5*h*k_11,Vz(i)+0.5*h*L_11);
    L_22 = F_Vz(t(i)+0.5*h,Z(i)+0.5*h*k_11,Vz(i)+0.5*h*L_11);
    k_33 = F_Z(t(i)+0.5*h,Z(i)+0.5*h*k_22,Vz(i)+0.5*h*L_22);
    L_33 = F_Vz(t(i)+0.5*h,Z(i)+0.5*h*k_22,Vz(i)+0.5*h*L_22);
    k_44 = F_Z(t(i)+    h,Z(i)+ h*k_33,Vz(i)+   h*L_33);
    L_44 = F_Vz(t(i)+   h,Z(i)+ h*k_33,Vz(i)+   h*L_33);    X(i+1) = X(i) + (h/6)*(k_1+2*k_2+2*k_3+k_4);
    Vx(i+1) = X(i) + (h/6)*(L_1+2*L_2+2*L_3+L_4);
    Z(i+1) = Z(i) + (h/6)*(k_11+2*k_22+2*k_33+k_44);
    Vz(i+1) = Z(i) + (h/6)*(L_11+2*L_22+2*L_33+L_44);
end
plot(t,X,'--', 'Linewidth', 1.5, 'color', 'red')
hold on
plot(t,Vx,'--', 'Linewidth', 1.5, 'color', 'black')
hold on
plot(t,Z,'--', 'Linewidth', 1.5, 'color', 'blue')
hold on
plot(t,Vz,'--', 'Linewidth', 1.5, 'color', 'yellow')
xlabel('time')
ylabel('height')
legend('X','Vx','Z','Vz')
i did it , however now the problem is on my graph when i generate it, i am doing a trajectory simulation of a free-fall lifeboat falling from a height of 5m above water level, the current graph i generate out starts from 0
and i should get something like the picture i attached
can you help me see is there anything wrong with my code?
thank you
Related to 4th order Runge Kutta Matlab with 2 2nd order ode
1. What is 4th order Runge Kutta method in Matlab?
The 4th order Runge Kutta method is a numerical method used to solve ordinary differential equations (ODEs) in Matlab. It is a popular method because it is more accurate than other numerical methods, such as Euler's method, while still being relatively simple to implement.
2. How does the 4th order Runge Kutta method work?
The 4th order Runge Kutta method works by approximating the solution to an ODE at discrete time steps. It uses a weighted average of four different estimates of the solution at each time step, with the weights determined by the derivatives of the ODE. This allows for a more accurate approximation of the solution compared to other methods.
3. How do you implement 4th order Runge Kutta method in Matlab?
To implement the 4th order Runge Kutta method in Matlab, you first need to define the ODE as a function. Then, you can use the "ode45" function with the defined ODE function as an input to solve for the solution at each time step. Alternatively, you can write your own code using the algorithm of the 4th order Runge Kutta method.
4. Can the 4th order Runge Kutta method be used for higher order ODEs?
Yes, the 4th order Runge Kutta method can be used for any order of ODEs. However, for higher order ODEs, they need to be converted to a system of first order ODEs before using the method. This can be done by introducing new variables and rewriting the higher order derivatives as first order derivatives.
5. What are the advantages and disadvantages of using 4th order Runge Kutta method in Matlab?
The main advantage of using 4th order Runge Kutta method in Matlab is its accuracy, as it provides a better approximation of the solution compared to other numerical methods. However, it can be computationally expensive for large systems of ODEs and may not be suitable for stiff ODEs. It also requires knowledge of the derivatives of the ODE, which may not always be readily available.
