5 charges placed at 5 vertices of a regular hexagon
In summary: From symmetry the field at the centre due to 4 point charges gets canceled and therefore the field due to all the 5 point charges will actually be due to a single point charge at the centre which is $$\frac{q}{4\pi\epsilon_0a^2}$$ and similarly the potential at the centre due to all the 5 point charges is $$\frac{5q}{4\pi\epsilon_0a}$$
Apashanka
429
If 5 charges (each q) are placed at 5 vertex of a regular hexagon of side a then effectively the electric field at the centre of the hexagon is $$\frac{q}{4\pi\epsilon_0} $$
If 5 charges (each q) are placed at 5 vertex of a regular hexagon of side a then effectively the electric field at the centre of the hexagon is $$\frac{q}{4\pi\epsilon_0a^2} $$ but the potential is $$\frac{5q}{4\pi\epsilon_0a}$$ but then what about $$V=-\int \textbf{E•dr}$$
A hexagon has six vertexes. Perhaps you meant a pentagon? Or should one vertex be left without a charge?
One vertex left without charge
What about it? It's a line integral (or more generally a path integral), so you need to define two endpoints and a path between them.
If you are asking how to find the electric field from the potential, you need to find the potential at a point ##\{x,y\}## off the center, find the gradient ##\text{-}\vec \nabla V## and then calculate it at the origin. However, there is a quicker way to answer this question that exploits symmetry and superposition.
Likes hutchphd
The electric field is a vector quantity so you need also to specify the direction of the field.
My question is from $$V=-\int E • dr$$ here in this case we get the potential as $$\frac{q}{4\pi\epsilon_0a}$$ which is not consistent with above??
How do you get that potential from that integral? Are you trying to integrate kq/a2 with a as the variable? That is not correct. kq/a2 is the value of the field at the centre; it is not a formula for the field over a space defined by the supposed variable a.
Likes Apashanka
Related to 5 charges placed at 5 vertices of a regular hexagon
1. What is a regular hexagon?
A regular hexagon is a polygon with six equal sides and six equal angles. It is a type of equilateral polygon, meaning all of its sides are the same length.
2. How many charges are placed at the vertices of a regular hexagon?
There are five charges placed at the vertices of a regular hexagon. Each vertex represents a point where two sides of the hexagon meet.
3. What is the significance of placing charges at the vertices of a regular hexagon?
Placing charges at the vertices of a regular hexagon allows for equal distance between each charge and creates a symmetrical distribution of charges. This can be useful in studying the effects of electric fields and forces.
4. How are the charges distributed on a regular hexagon?
The charges are evenly distributed on the regular hexagon, with one charge placed at each vertex. This creates a symmetrical distribution and allows for equal distance between each charge.
5. Can the charges be placed at different positions on the regular hexagon?
Yes, the charges can be placed at different positions on the regular hexagon. However, this would result in an asymmetrical distribution and may affect the overall electric field and forces within the system.
