- #36
Bob S
- 4,662
- 7
Maybe I misread the specs, but if the output range is 500 mA max into a 1 to 100 ohm resistor, then you need to use a power supply capable of 60 volts at 500 mA, and output transistor ratings of Vceo of 60 volts and 50 watts. I suggest a PNP darlington TIP125, which has an hfe of 1000. Also I suggest that the output load be ground referenced, so with the suggested PNP darlington, the sense resistor (about 10 ohms) is between the +60 volts and the emitter, with the load connected between the collector and ground.
