5x5 Arrays - Sum & Difference - (Fortran)
In summary: Yes, I changed the spelling of "arrB" to "arrB". I also would like to know how to calculate the sum and difference of two 2D arrays.
Const@ntine
285
Create two 5x5 arrays, A & B, and ask the person to fill them out. Save those numbers in matrix_a.txt & matrix_b.txt respectively. Then, save the sum and difference of those numbers in sum.txt & diff.txt respectively.
Basically we need to create two arrays, fill them out, save the numbers in .txt files using the ofstream file_name("...") command, and then do the same (.txt) for their sum and difference.
It needs to be done in C++ & Fortran languages.
I have done the C++ version already:
C:
#include <iostream>
#include <cmath>
#include <fstream>
#include <cstdlib>
using namespace std;
int main()
 double arrA[5][5];
 double arrB[5][5];
 double arrPAB[5][5];
 double arrDAB[5][5];
 int i, j, k, l;
 double sumAB, difAB;
 ofstream arrayA("matrix_a.txt");
 ofstream arrayB("matrix_b.txt");
 ofstream arrayPlus("sum.txt");
 ofstream arrayMinus("dif.txt");
 for(i = 0; i<5; i++)
   for(j=0; j<5; j++)
   cout << "Enter the values for Measurement No " << i << " in arrA(" << i << ") (" << j << "): ";
   cin >> arrA[i][j];
   arrayA << arrA[i][j] << " ";
  cout << endl << endl;
 for(k=0; k<5; k++)
   for(l=0; l<5; l++)
   cout << "Enter the values for Measurement No " << k << " in arrB(" << k << ") (" << l << "): ";
   cin >> arrB[k][l];
   arrayB << arrB[k][l] << " ";
  sumAB = 0;
  difAB = 0;
  for(i=0, k=0; i<5, k<5; i++, k++)
    for(j=0, l=0; j<5, l<5; j++, l++)
    sumAB += (arrA[i][j] + arrB[k][l]);
    difAB += (arrA[i][j] - arrB[k][l]);
    arrayPlus << "The sum of the two Arrays is: " << sumAB << " ";
    arrayMinus << "The difference between the two Arrays is: " << difAB << " ";
 return 0;
I've checked it, and it works alright. But I have problems with the Fortran version:
Fortran:
PROGRAM Arrays5x5
REAL, DIMENSION (5,5) :: ARRA
REAL, DIMENSION (5,5) :: ARRB
REAL, DIMENSION (5,5) :: ARRPAB
REAL, DIMENSION (5,5) :: ARRDAB
INTEGER :: I, J, K, L
REAL :: SUMAB, DIFAB
OPEN (UNIT=13, FILE='matrix_a.txt')
OPEN (UNIT=14, FILE='matrix_b.txt')
OPEN (UNIT=15, FILE='sum.txt')
OPEN (UNIT=16, FILE='dif.txt')
DO I = 0, 5
DO J = 0, 5
PRINT *, 'Enter the values in arrA(' ,I , ') (' ,J , '): '
READ *, ARRA(I)(J)
WRITE(13,*) ARRA(I)(J), ' '
END DO
END DO
CLOSE(UNIT=13)
PRINT*
PRINT*
DO K = 0, 5
DO L = 0, 5
PRINT *, 'Enter the values in arrB(' ,K , ') (' ,L , '): '
READ *, ARRA(K)(L)
WRITE(14,*) ARRA(K)(L), ' '
END DO
END DO
CLOSE(UNIT=14)
SUMAB = 0
DIFAB = 0
DO I = 0, K = 0, 5, 5
DO J = 0, L = 0, 5, 5
SUMAB = SUMAB + (ARRA(I)(J) + ARRB(K)(L))
DIFAB = DIFAB + (ARRA[I][J] - ARRB[K][L])
WRITE(15,*), 'The sum of the two Arrays is: ', SUMAB
WRITE(16,*), 'The diferrence between the two arrays is: ', DIFAB
END DO
END DO
CLOSE(UNIT=15)
CLOSE(UNIT=16)
END PROGRAM
Any help is appreciated!
Fortran:
DO I = 0, 5
DO J = 0, 5
READ *, ARRA(I)(J)
END DO
END DO
Do you realize that the body of you nested do loops is running 36 times, not 25 times?
Your do loops should be DO I = 1,5, and similar for the loop on J.
It looks like you have a typo here in the first two lines. For the sum or difference of two 2D arrays, use nested DO loops just like you used to enter values in each array (but run your loop indexes from 1 to 5, not 0 to 5).
Fortran:
END DO
END DO
What problems, specifically? Saying you have problems gives us just about zero to go on.
Does your Fortran program compile? If not, the compiler will give you information about where the syntax error is located.
If the program compiles, does it produce incorrect results? If so, what are the results, and how are they different from the results you expected.
Likes FactChecker
What problems are you having? Please don't make us guess.
Likes mfb
Darthkostis said:
DO K = 0, 5
DO L = 0, 5
READ *, ARRA(K)(L)
END DOi
END
DO
I believe it should be "ARRB" instead of "ARRA" on these line. Furthermore, it would be useful if you could post the error you are getting. Otherwise it is difficult help you.
You are storing data in FORTRAN array index 0, which is not the default. Putting data outside of the legitimate array bounds can cause a lot of bazaar behavior. Start your FORTRAN loops at index 1.
Mark44 said:
Fortran:
DO I = 0, 5
DO J = 0, 5
READ *, ARRA(I)(J)
END DO
END DO
Yeah, that was a rookie mistake (well, all things considered I don't have tons of hands-on). I fixed that one now.
Yeah, sorry about that. I rushed it a bit, that's true (it was getting late and it's been a long day). Anyway, the problem is that it doesn't even compile. I looked a bit on the net and with this being pointed out:
I found out that I had written ARRB(K)(L) instead of the proper ARRB(K,L) (first time working with arrays with more than one dimension in Fortran).
Fortran:
DO K = 1, 5
DO L = 1, 5
READ *, ARRB(K,L)
WRITE(14,*) ARRB(K,L), ' '
END DO
END DO
CLOSE(UNIT=14)
With that fixed, I'm having trouble with the final nested loop, where I have to "create" the sum and difference of the two. The compiler gives me this:
---------- Capture Output ----------
> "C:\Emerald\gfortran.bat" -ffree-form BF.f BF
BF.f:40:12:
DO I = 1, K = 1, 5, 5
Error: Syntax error in DO statement at (1)
BF.f:41:12:
DO J = 1, L = 1, 5, 5
BF.f:46:3:
END DO
Error: Expecting END PROGRAM statement at (1)
BF.f:47:3:
END DO
> Terminated with exit code 1.
So I guess the problem lies there.
Yes. Those loops look wrong to me. As in the earlier loops, just control one index, I, in an outer loop and loop the other index, J within that outer loop. I don't think that you want the K and L indices at all. I would interpret the problem as asking for element-by-element sum and difference of the two matrices. That is a common thing to do with matrices. If you really want total sums of all elements, you can keep running totals as the user inputs each number. I think that your C version has the same misconception.
Likes Const@ntine
Darthkostis said:
Yeah, that was a rookie mistake (well, all things considered I don't have tons of hands-on). I fixed that one now. Yeah, sorry about that. I rushed it a bit, that's true (it was getting late and it's been a long day). Anyway, the problem is that it doesn't even compile. I looked a bit on the net and with this being pointed out:
Fortran:
DO K = 1, 5
DO L = 1, 5
READ *, ARRB(K,L)
END DO
END DO
CLOSE(UNIT=14)
BF.f:40:12:
BF.f:41:12:
BF.f:46:3:
END DO
BF.f:47:3:
END DO
I guess what you want here are two loops one over for I and another over K. However, I believe the syntax is not correct. You have to write with two Do statements.
Well, the exercise is not exactly clear about this, but what I got from it is that I just need the sum of ARRA(1)(1) + ARRB(1)(1) + ... ARRA(5)(5) + ARRB(5)(5). I went with all 1s on ARRA & all 2s on ARRB for an easy "test drive", and the sum should be 75, while the difference should be -25. Problem is, I tried skipping K and L, but I don't get a good result:
Diferrence:
The diferrence between the two arrays is: 0.00000000
Sum:
The sum of the two Arrays is: 4.00000000
The sum of the two Arrays is: 6.00000000
The sum of the two Arrays is: 8.00000000
The sum of the two Arrays is: 10.0000000
The sum of the two Arrays is: 12.0000000
The sum of the two Arrays is: 14.0000000
The sum of the two Arrays is: 16.0000000
The sum of the two Arrays is: 18.0000000
The sum of the two Arrays is: 20.0000000
The sum of the two Arrays is: 22.0000000
The sum of the two Arrays is: 24.0000000
The sum of the two Arrays is: 26.0000000
The sum of the two Arrays is: 28.0000000
The sum of the two Arrays is: 30.0000000
The sum of the two Arrays is: 32.0000000
The sum of the two Arrays is: 34.0000000
The sum of the two Arrays is: 36.0000000
The sum of the two Arrays is: 38.0000000
The sum of the two Arrays is: 40.0000000
The sum of the two Arrays is: 42.0000000
The sum of the two Arrays is: 44.0000000
The sum of the two Arrays is: 46.0000000
The sum of the two Arrays is: 48.0000000
The sum of the two Arrays is: 50.0000000
The problem is that I have 4 variables. If I go with 4 Dos, well, the whole thing breaks. If I go with 2 loops, two of those are skipped, and I get faulty results.
It is a bit unclear for me what is meant with sum and difference. For example sum can mean C=A+B, i.e. the elements of C can be C(i,j)=A(i,j)+B(i,j). Or the total sum of all elements in the matrices A and B, i.e. sum(C)=sum(A)+sum(B). As they ask you print the sum to file it seems to be first case. Then, you only need the two variables i and j. It will of course be similar for the difference.
Well, it's a bit unclear to me as well to be honest. From what I'm getting, it is: Sum = [aij + bkl] & Difference = [aij - bkl]. So that's why I'm goign with the loops. Not to be a PITA, but would you mind turning what you're proposing I do into code, because I'm not sure I'm getting it.
Well, I mean something like
Fortran:
Do k=1, N
Do j=1, N
c(k,j)=a(k,j)+b(k,j)
end do
end do
But, it seems now like you should combine all elements of a and b, so ##sum=[a_ij+b_kl]##. However, I still don't understand why you get problems if you use four loops. It should be possible.
Fortran:
Do k=1, N
Do j=1, N
end do
end do
Ah yup, that works just fine. I guess I overcomplicated the C++ version and then tried to do the same with the Fortran one.
Either way, thanks a ton for the help everybody, I greatly appreciate it!
Likes FactChecker
You are welcome!
Likes Const@ntine
FAQ: 5x5 Arrays - Sum & Difference - (Fortran)
What is a 5x5 array in Fortran?
A 5x5 array in Fortran is a data structure that can store a table of 25 elements, with 5 rows and 5 columns. It is a commonly used method for organizing and manipulating large amounts of data in scientific computing.
How do you sum a 5x5 array in Fortran?
To sum a 5x5 array in Fortran, you can use a nested do-loop structure. First, initialize a variable to hold the sum. Then, use two do-loops to iterate through each element in the array and add it to the sum variable. At the end of the loops, the sum variable will contain the total sum of all elements in the array.
Can you use the sum function in Fortran to sum a 5x5 array?
Yes, the sum function in Fortran can be used to sum a 5x5 array. However, it is important to note that the sum function only works on one-dimensional arrays. Therefore, you would need to reshape the 5x5 array into a one-dimensional array before using the sum function.
How do you find the difference between two 5x5 arrays in Fortran?
To find the difference between two 5x5 arrays in Fortran, you can use a nested do-loop structure similar to summing an array. Instead of adding the elements, you would subtract the elements from one array from the corresponding elements in the other array. The resulting array would contain the differences between the two arrays.
What is the advantage of using arrays over individual variables in Fortran?
Using arrays in Fortran allows for more efficient and organized storage and manipulation of data. It also allows for easier iteration and processing of large amounts of data. Additionally, arrays make it easier to perform mathematical operations on multiple elements at once, which is essential in scientific computing.
