MHB 6.2.8 {{k,4},{3,k}}=k what is k
  • Thread starter Thread starter karush
The discussion centers on finding the positive real value of k for which the determinant of the matrix [[k, 4], [3, k]] equals k. The determinant is calculated as k^2 - 12, leading to the equation k^2 - k - 12 = 0. Factoring this equation gives (k - 4)(k + 3) = 0, resulting in k = 4 and k = -3. Since only the positive solution is relevant, k is determined to be 4. Verification of the solution confirms that substituting k back into the original determinant equation holds true.
karush
MHB
What positive real value of \textbf{k}, is the determinant of the Matrix
$\begin{bmatrix}
k & 4\\3 & k
\end{bmatrix}$
equal to $k$?
a.3 b.4 c.12 d. $\sqrt{12}$ e. none $k^2-12=k\implies k^2-k-12=0\implies k^2-k-12=0\implies (k+3)(k-4)=0$
$k=\boxed{4}$
ok basically I think most could just eyeball this and get it
but when I tried to ck it in W|A it froze,,,
W|A
Mathematics news on Phys.org
got it :unsure:
Yes, what you have done is exactly correct!
$$\left|\begin{array}{cc} k & 4\\ 3 & k\end{array}\right|= k^2- 12= k$$.
[math]k^2- k- 12= (k- 4)(k+ 3)= 0[/math].
k= -3 and k= 4. Since the question asks for the "positive" solution, the answer is "4". Well done!
I would not use Wolfram alpha or any tool to check- just put k= 4 back in the original equation:
$$\left|\begin{array}{cc} k & 4\\ 3 & k\end{array}\right|= \left|\begin{array}{cc} 4 & 4\\ 3 & 4\end{array}\right|= 4^2- 12= 16- 12= 4= k$$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
