6-dimensional representation of Lorentz group
In summary: This is because it is an anti-symmetric rank two tensor in 4D spacetime, which corresponds to a 6-dimensional vector space. The Faraday tensor also has two invariants that are proportional to the electric and magnetic fields, which are used to form the Riemann-Silberstein vector. This vector is a representation of the proper orthochronous Lorentz group, and the subgroup ##\mathrm{SO}(3,\mathbb{R})## represents rotations while the boosts are represented by imaginary angle rotations.
Silviu
624
Hello! I understand that the vector formed of the scalar and vector potential in classical EM behaves like a 4-vector (##A^\nu=\Lambda^\nu_\mu A^\mu##). Does this means that the if we make a vector with the 3 components of B field and 3 of E field, so a 6 components vector V, will it transform as ##V^\nu=M(\Lambda^\nu_\mu) V^\mu##, with M being a 6-dimensional representation of the Lorentz group? So can we build all the tensorial formalism of EM using this 6-dimensional representation, in the same way we did with a 4-vector representation?
Silviu said:
). Does this means that the if we make a vector with the 3 components of B field and 3 of E field, so a 6 components vector V, will it transform as Vν=M(Λνμ)VμVν=M(Λμν)VμV^\nu=M(\Lambda^\nu_\mu) V^\mu,
Not quite. The relativistic object which contains the components of both the non relativistic E and B field is called the Faraday tensor. It is a rank 2 tensor in 4D spacetime, so it has 16 components. But the Faraday tensor is antisymmetric, so it only has 6 independent components (the diagonal elements are 0 and the upper triangle is the opposite of the lower triangle)
So the vector I just described, doesn't transform in a relativistic from, it must be through a tensor?
Well, technically what you described is not even a vector. A vector has 4 components in relativity, so something with 6 components cannot be a vector.
Oh, so what is the point of a n-dimensional representation of the Lorentz group, if it makes sense only for n=4?
There are two convenient ways to get the transformation of the electromagnetic-field components. First you can use the Faraday tensor components,
$$F_{\mu \nu}=\partial_{\mu} A_{\nu} - \partial_{\nu} A_{\mu},$$
which transform as any 2nd-rank-tensor components
$$\bar{F}^{\mu \nu}(\bar{x}) = {\Lambda^{\mu}}_{\rho} {\Lambda^{\nu}}_{\sigma} F^{\rho \sigma}(x).$$
The second posibility is to use the Riemann-Silberstein vector. In terms of the field components in the 1+3-formalism it reads
$$\vec{F}=\vec{E}+\mathrm{i} \vec{B}.$$
The two invariants one can form from the ##F_{\mu \nu}## are ##F_{\mu \nu} F^{\mu \nu}## and ##\epsilon_{\mu \nu \rho \sigma} F^{\mu \nu} F^{\rho \sigma}##, which are proportional to ##\vec{E}^2-\vec{B}^2## and ##\vec{E} \cdot \vec{B}##. Now using the usual scalar product for the complex RS vector, shows that under Lorentz transformations the scalar product
$$\vec{F} \cdot \vec{F} = (\vec{E}^2-\vec{B}^2) +2 \mathrm{i} \vec{E} \cdot \vec{B}$$
stays constant. Thus the representation of the proper orthochronous Lorentz group for the RS vector is ##\mathrm{SO}(3,\mathbb{C})##. It turns out that the subgroup ##\mathrm{SO}(3,\mathbb{R})## is the representation of the rotations as it must be since ##\vec{E}## and ##\vec{B}## are real three-vectors. Rotations around a fixed direction with imaginary angles, represent the boosts in the corresponding direction. They mix electric and magnetic components.
Likes dextercioby
The set of anti-symmetric rank two tensors form a 6-dimensional vector space so: Yes, indeed the Faraday tensor transforms according to a 6-dimensional representation of the Lorentz group.
It is not a vector in the typical nomenclature of relativity, but it is an element of a 6-dimensional vector space (the anti-symmetric rank two tensors) that allows a representation of the Lorentz group.
I would not use the regular space-time indices to denote the components of this vector space though.
The Faraday tensor indeed transforms under a 6-dimensional representation of the Lorentz group.
Likes PeterDonis
Related to 6-dimensional representation of Lorentz group
1. What is the 6-dimensional representation of the Lorentz group?
The 6-dimensional representation of the Lorentz group is a mathematical model used to describe the symmetries of special relativity in six-dimensional space. It is a linear representation that maps the six-dimensional space onto itself, preserving the symmetries of the Lorentz group.
2. How is the 6-dimensional representation related to special relativity?
The 6-dimensional representation is related to special relativity because it describes the transformations and symmetries that occur in six-dimensional space, which is necessary for accurately describing the principles of special relativity. In particular, it helps to understand how space and time are interrelated and how they can be transformed.
3. What are the applications of the 6-dimensional representation?
The 6-dimensional representation has many applications in theoretical physics and cosmology. It is used to study the properties of spacetime, such as the behavior of particles in curved spacetime and the effects of gravitational waves. It also helps to understand the dynamics of particles moving at high speeds and the behavior of systems in extreme conditions, such as black holes.
4. How is the 6-dimensional representation different from other representations of the Lorentz group?
The 6-dimensional representation is different from other representations of the Lorentz group because it is a higher-dimensional representation. Most other representations of the Lorentz group are four-dimensional, which is the number of dimensions in our observable universe. The 6-dimensional representation allows for a more complete understanding of the symmetries of special relativity.
5. What are the mathematical properties of the 6-dimensional representation?
The 6-dimensional representation has several important mathematical properties. It is a unitary representation, meaning that it preserves the inner product of vectors. It is also irreducible, meaning that it cannot be broken down into smaller representations. Additionally, it has a unique character, or set of eigenvalues, that distinguishes it from other representations of the Lorentz group.
