MHB -7.68 Determine the value z* to satisfy the following conditions
  • Thread starter Thread starter karush
    Conditions Value
To determine the value of z* for various probabilities under a normal distribution with a mean of 12 and a standard deviation of 2, the cumulative distribution function (CDF) of the standard normal distribution, denoted as Φ(z), is utilized. The relationship between z* and the probabilities is established through the equations P(z < z*) = Φ((z* - μ)/σ) and P(z > z*) = 1 - Φ((z* - μ)/σ). For specific probabilities, the inverse function Φ⁻¹(p) is applied to find the corresponding z-scores. An example calculation shows that for P(z < z*) = 0.025, the resulting z* is approximately 10.651. The discussion emphasizes the importance of using statistical tables or software for accurate z-score determination.
karush
MHB
$\tiny{7.68}$
Normal curve $\quad\mu=12\quad\sigma = 2$
Let z denote a variable that a standard normal distribution.
Determintie the value $z*$ to satisfy the following conditions:
a. $P(z<z*)=.025$
b. $P(z<z*)=.01$
c. $P(z<z*)=.05$
d. $P(z<z*)=.02$
e. $P(z>z*)=.01$
f. $P(z>z*)\textbf{ or }(z<-z*)=.20$
ok I want to do these one at a time especially a,d and f
example on page 411 of text
Mathematics news on Phys.org
$$\text{let $\Phi(z)$ be the CDF of the standard normal. That function they make tables of. You'll need some form of that.}\\~\\
\text{Then $\Phi\left(\dfrac{z - \mu}{\sigma}\right)$ is the CDF of a normal distribution centered at $\mu$ with standard deviation $\sigma$}\\~\\
\text{So $P(z < z^*) = \Phi\left(\dfrac{z^*-\mu}{\sigma}\right)$}$$
Similarly
$$P(z > z^*) = 1-\Phi\left(\dfrac{z^*-\mu}{\sigma}\right)$$
Finally for (f) the probability of two non-intersecting intervals is the sum of the individual interval probabilities.
You'll actually have to use the inverse function $$\Phi^{-1}(p)$$ as they give you probabilities.
For example (a)
$$P(z < z^*) = 0.25\\
\text{we look up in the table $0.25$ (actually I just use software) and find that it corresponds to a "z-score", as it's commonly known, of $-0.67449$}\\
\dfrac{z^* - \mu}{\sigma} = -0.67449\\~\\
z^* = \mu - 0.67449\sigma = 10.651$$
mahalo
ill try the rest
Similarly
For example (a)
mahalo
ill try the rest
Determintie the value z∗z∗ to satisfy the following conditions
[c] $P(z<z*)=.05$
$\quad\dfrac{z^* - \mu}{\sigma} =-5.975 \textbf{ so } z^*=(12)-5.975(2)=.05$
did something wrong...
z score calc
use calculate z from p
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
