MHB 7.t.27 Write an equation for a sinusoidal graph with the following properties:
The discussion focuses on deriving the equation for a sinusoidal graph with specified properties: an amplitude of -3, a period of \(\frac{2\pi}{3}\), and a phase shift of -\(\frac{\pi}{4}\). The correct equation is derived as \(y = -3\sin\left(3\left(x + \frac{\pi}{4}\right)\right)\), emphasizing that the amplitude is expressed as a positive value regardless of the sign in front. Clarification is provided that the amplitude should be represented as the absolute value, which is 3, and the phase shift's sign is reversed in the equation. The final equation accurately reflects the properties given, resolving initial confusion about the amplitude's negative value.
karush
MHB
$\tiny{7.t.27}$
$\textsf{Write an equation for a sinusoidal graph with the following properties:}\\$
$$A=-3,
\textsf{Period}=\frac{2\pi}{3},
\textsf{Phase Shift}=-\frac{\pi}{4}$$
\begin{align*}\displaystyle
A&=-3\\
T&=\frac{2\pi}{3}=\frac{2\pi}{\omega}\\
\omega&=3\\
PS&=-\frac{\pi}{4}=\frac{\phi}{\omega}\\
\phi&=\pi
\end{align*}
y_{27}&=A\sin{\left[\omega\left(x-\frac{\phi}{\omega} \right)\right]}
\end{align*}
$\textit{so then}$
Y_{27}&=-3\sin{\left[3\left(x-\frac{\pi}{12} \right)\right]}
\end{align*}
hopefully:confused:
Mathematics news on Phys.org
The amplitude of a sinusoidal function is one-half the vertical distance between the minimum and maximum, and so should never given as a negative value. Given:
$$y=A\sin\left(\omega(x-\phi)\right)\tag{1}$$
The amplitude is then $|A|$. Thus, both of the following have an amplitude of 3 units:
$$y=3\sin(x)$$
$$y=-3\sin(x)$$
You have the correct angular velocity $\omega$, but in (1) the phase shift is $\phi$ and so $\phi$ will have the opposite sign of the value given for the phase shift:
$$y=3\sin\left(3\left(x-\left(-\frac{\pi}{4}\right)\right)\right)=3\sin\left(3\left(x+\frac{\pi}{4}\right)\right)$$
here is what was given...
My mind must've been on something other than this problem when I posted last night...$A=-3$ is not saying the amplitude is -3...so what I would give is:
$$y=-3\sin\left(3\left(x+\frac{\pi}{4}\right)\right)$$
Sorry for the confusion. :D
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
11K
11K
