7-year WMAP data: cosmo implications
  • Thread starter marcus
  • Tags
    Data
In summary: Standard Model's prediction has to be taken seriously. On the other hand, there are also a significant number of well respected theories that are completely fine with four or five neutrino generations.The WMAP team does an interesting job of looking at some of the consequences of four or five neutrino generations, and in some ways, they are a better fit for the data than three. For example, the predicted Hubble constant is closer to what the WMAP data suggest with four or five generations than the three generation prediction. This is because more massive neutrinos would have more of a tendency to slow down the rate of expansion of the universe as it aged, than three neutrino generations would.Also, the fourth and fifth
marcus
Dearly Missed
24,775
792
http://arXiv.org/abs/1001.4538
Seven-Year Wilkinson Microwave Anisotropy Probe (WMAP) Observations: Cosmological Interpretation
E. Komatsu, K. M. Smith, J. Dunkley, C. L. Bennett, B. Gold, G. Hinshaw, N. Jarosik, D. Larson, M. R. Nolta, L. Page, D. N. Spergel, M. Halpern, R. S. Hill, A. Kogut, M. Limon, S. S. Meyer, N. Odegard, G. S. Tucker, J. L. Weiland, E. Wollack, E. L. Wright
48 pages, 19 figures. Submitted to Astrophysical Journal Supplement Series
(Submitted on 25 Jan 2010)
"(Abridged) The 7-year WMAP data and improved astrophysical data rigorously tests the standard cosmological model and its extensions. By combining WMAP with the latest distance measurements from the Baryon Acoustic Oscillations (BAO) and the Hubble constant (H0) measurement, we determine the parameters of the simplest LCDM model. The power-law index of the primordial power spectrum is ns=0.963+-0.012, a measurement that excludes the scale-invariant spectrum by more than 3-sigma. The other parameters, including those beyond the minimal set, are also improved from the 5-year results. Notable examples of improved parameters are the total mass of neutrinos, sum(mnu)<0.58eV, and the effective number of neutrino species, Neff=4.34+0.86-0.88, which benefit from better determinations of the third peak and H0. We detect the effect of primordial helium on the temperature power spectrum and provide a new test of big bang nucleosynthesis. We detect, and show on the map for the first time, the tangential and radial polarization patterns around hot and cold spots of temperature fluctuations, an important test of physical processes at z=1090 and the dominance of adiabatic scalar fluctuations. With the 7-year TB power spectrum, the limit on a rotation of the polarization plane due to potential parity-violating effects has improved to Delta(alpha)=-1.1+-1.3(stat)+-1.5(syst) degrees. We report a significant detection of the SZ effect at the locations of known clusters, and show that the current simulations and analytical calculations overestimate the gas pressure, and do not reproduce the observed gas pressure in clusters of galaxies. This result is consistent with the lower-than-expected SZ power spectrum recently measured by the SPT collaboration."
For the whole series of 7-year WMAP reports see:
http://lambda.gsfc.nasa.gov/product/map/dr4/map_bibliography.cfm
Space news on Phys.org
This proves conclusively that Stephen Hawking is god.
(anomalies paper, page 14)
Heh heh, some apparently random squiggles in the temperature map resemble the letters S and H, too bad nobody predicted that ahead of time. :wink:
The Anomalies paper (Bennett et al) put a box around that patch of the map, to show where the initials are, to make a point about a postiori interpretation.
Thanks for the reference.
If anyone hasn't already seen this, look at Figure 17, on page 14 of http://arXiv.org/abs/1001.4758
7-year WMAP leans toward flat infinite LambdaCDM
People can argue about the fine points of interpretation and exactly what words to use in describing the current expert hunches and leanings. The issue certainly is not resolved.
But the Komatsu et al 5-year WMAP paper left more room for the possibility of a positive curved spatial finite LambdaCDM model. It even at one point calculated a lower bound on what the radius of curvature would be---around 100 billion lightyears (now distance, freezing expansion).
That was in Table 2 of WMAP5 Komatsu.
The corresponding WMAP7 paper spends much less time considering that case, and also focuses more on the w=-1 case---the straight LambdaCDM model, no exotic "dark energy", just a simple cosmological constant Lambda.
http://arXiv.org/pdf/1001.4538
There are good reasons for this, I think. As more data accumulates and the errorbounds shrink, the range of uncertainty narrows, it looks increasingly like the simple flat LambdaCDM case.
So they put that up front in their first paragraph.
And they also dropped a little footnote about the 68% confidence interval for Omegak
The 95% confidence interval they use on page 3, for Table 2 is: -0.0133 < Ωk < 0.0084
But if you read further, you find on page 18 this footnote:
The 68% CL limit is Ωk = −0.0023+0.0054-0.0056
which translates to -0.0079 < Ωk < 0.0031
Of course you could say that is LOPSIDED in favor of positive spatial curved, spatial finite universe. But I think the main point is that they are really squeezing the thing down around zero.
For people who are more familiar with the Ωtot notation, Ωk is defined to be 1 - Ωtot. So there is a funny sign-reversal in the notation that you need to be aware of. Negative Ωk corresponds to positive spatial curvature---the hypersphere picture rather than the infinite flat spatial extent.
So since a lot of us are used to reading Ωtot = 1 for "flat" I will translate.
The 68% confidence interval says:
0.9969 < Ωtot < 1.0079
You can see that it has been narrowed down quite a bit since WMAP5 and that it is even more lopsided than it was before, in favor of Omega being slightly bigger than one, which is the spatial finite case.
However the first lesson to take away is that it has narrowed and that the zero curved Omega = 1 point is still in the interval.
Most of the WMAP data are doing what physicist thought would be happening at the end of the 19th century, modestly refining physical constants we already had good ball park estimates for, in this case, lambda cold dark matter constants.
The "shocker" of the paper is its suggestion that the WMAP data are more consistent with four or five neutrino generations (with four being more likely than five, but five being more likely than three) than it is with three neutrino generations. Three neutrinos are still within two standard deviations of the expected number of generations based upon the data, however.
The Standard Model, of course, has only three neutrino generations, although adding a fourth generation of fermions to it wouldn't wreck total havoc on the core Standard Model, since the Standard Model doesn't purport to explain why we have the number of fundamental particles or fundamental constants that described them.
But, a significant number of the theories that try to explain the Standard Model's particle zoo and constants from first principles offer up deep reasons (e.g. from symmetry) that there must be exactly three generations of fermions.
Since WMAP is such gold standard data, a result at odds with the standard model drawn from it has more credibility than the usual "here's another Beyond The Standard Model theory" preprint. Since WMAP is generally consistent with prior observations of cosmic background radiation, and involves a one of a kind phenomena, it is also data that won't be refuted in further experiments. One can rethink the theory used to derive the conclusion reached, but the data aren't going to change materially.
On the other hand, new results of the MINOS collaboration at Fermilab (http://www.symmetrymagazine.org/breaking/2010/02/02/new-minos-results-%e2%80%9cstrongly-disfavor%e2%80%9d-sterile-neutrino-neutrino-decay/ ) disfavor a fourth generation neutrino, at least if it fits the profile of a "sterile neutrino."
The math that is being used to make the WMAP conclusion is also not purely "ex post" theorizing. There was published work on this kind of analysis in 1999 in JETP Letters
( http://www.springerlink.com/content/v34lxuh37727r3p4/ ) (and probably elsewhere as well), before WMAP data was available to prove it. This was analyzed, ex post, with the five year WMAP data ( http://en.wikipedia.org/wiki/Neutrino#Mass ).
Improvement in Omega_K comes mostly from the better supernova data they are using.
Hi marcus,
I just wanted to ask you if you could clarify what you meant here. I thought that "dark energy" was the prevailing interpretation of the effects of the cosmological constant (i.e. physical "explanation" for them), and that taking w = -1 just means saying that this dark energy has a particularly simple equation of state: p = -ϱc2. It sounded kind of like you were saying that w = -1 excludes dark energy altogether as an explanation for the cosmological constant (in favour of...?). This could be more a case of semantics/terminology, and again, it is not my intention to nitpick your wording or criticize you, I just wanted clarification on what you were saying, because I'm sure you have much more insight into Λ than I do as well as a better handle on what the standard terminology in the field is.
By the way, thanks so much for summarizing the key results of the paper so neatly!
Yeah, my wording wasn't clear. I meant no exotic dark energy. I think of the cosmological constant form of dark energy, with w = 1, as somehow normal. It is familiar and ordinary dark energy---what I naturally think of in connection with dark energy.
If dark energy is NOT associated with a simple cosmological constant then I think of it as exotic---strange weird. Maybe it is not constant, maybe the energy density is changing with time. Or maybe the equation of state w is changing with time. Something weird.
I need some word for non-normal dark energy. Do you think "exotic" works? Can you suggest an alternative?
Should I say "abnormal w≠1 dark energy"?
Anyway, do you understand what I was trying to say?
Gotcha
Sure?
I don't have any ideas...
Yup!
I think Quintessence is close. Or the fifth elephant.
Marcus, thanks for point out this very good paper to us.
Am I correct in understanding that the idea of inflation in the early (<<1second) universe leads us to expect a universe close to flat?
You are most welcome! I hope more people will take a look at the WMAP7 results.
That is correct about inflation. The observation that the universe is nearly flat has become one of the strongest motivations for assuming some kind of inflation occurred.
You probably know the main arguments for inflation
1. observed flatness or near flatness
2. observed background temperature near uniformity (nearly same temperature in all directions)
3. observed scale invariance of fluctuations in the background temperature map (intuitively, as much narrow-angle fluctuation as wide-angle, as much variation in the little bumps as in the big blotches)---a feature of the angular power spectrum.
It is hard to think of some early universe process besides inflation that would cause those things. Inflation itself is not so attractive because it requires some exotic field, some never-yet-observed "dark-energy-on-steroids" which causes terrific expansion and then abruptly decays. It is very contrived. No model of physics predicts an energy field like that. The reason inflation is widely accepted is because nobody can think of an attractive simple alternative that would account for things like 1. 2. and 3.
There are other scenarios but they aren't so popular because they are even more weird and exotic, or they don't do as good a job explaining, or they explain only one or two of the oddities but not the third, and so on.
I suspect that's familiar ground for you. In any case definitely YES. Inflation, if you buy it, will explain the observed flatness or near-flatness.
4. I forgot another thing that inflation helps explain---we don't observe magnetic monopoles. A bunch may have been created near the start of expansion but then inflation "diluted" them by creating this huge volume of space. Explains why they are so rare that they seem not to exist. (For some reason this justification of inflation is one I don't hear about much any more, maybe the first 3 reasons are more obvious.)
Related to 7-year WMAP data: cosmo implications
1. What is the WMAP data and why is it important?
The WMAP (Wilkinson Microwave Anisotropy Probe) is a satellite mission launched by NASA in 2001 to measure the cosmic microwave background (CMB) radiation. This data has provided important insights into the early universe, including the age, composition, and expansion rate of the universe.
2. What does the 7-year WMAP data reveal about the universe?
The 7-year WMAP data has revealed that the universe is approximately 13.75 billion years old and is made up of about 4.6% ordinary matter, 23% dark matter, and 72% dark energy. It has also provided evidence for the theory of cosmic inflation, which explains the rapid expansion of the universe in the first fractions of a second after the Big Bang.
3. How does the WMAP data support the Big Bang theory?
The WMAP data provides strong evidence for the Big Bang theory by showing the presence of a uniform background radiation across the entire sky, known as the cosmic microwave background (CMB). This supports the idea that the universe was once in a hot, dense state and has been expanding and cooling ever since.
4. What are some of the implications of the WMAP data for cosmology?
The WMAP data has had significant implications for our understanding of the universe and its origins. It has confirmed the age and composition of the universe, provided evidence for the theory of cosmic inflation, and helped to refine our understanding of the structure and evolution of the universe. It has also opened up new avenues for research and exploration in cosmology.
5. How is the WMAP data collected and analyzed?
The WMAP satellite collects data by scanning the entire sky in 5 different frequency bands using a specialized telescope. This data is then analyzed using sophisticated computer algorithms to remove noise and isolate the CMB signal. The resulting data is compared to theoretical models and used to make predictions and draw conclusions about the universe.
