[991es+] how to calc: (xi - meanX) ?
In summary, to calculate (xi - meanx ) on a Casio 991ES + calculator in static mode, you need to first enter the list of numbers for x and calculate the mean using the "STAT" mode. Then, enter the list of numbers for x again and subtract the mean from each element to get the desired result.
artiny
hy
i have a problem...i want to calculate for example this:
x = [1 2 3 4 5 6] meanx = 3.5
y = [ ... ] y = ... >>> calc: (xi - meanx )*(yi - meany)
the mean is calculate the casio 991es + in static mode...but how to calculate this 1st part:
(xi - meanx ) ?
in MATLAB we did like this:
( x - mx)*( x - mx)'
Computer science news on Phys.org
where mx is the mean of x.To calculate (xi - meanx ) on a Casio 991ES + calculator in static mode, you can use the following steps:1. Press the "STAT" button to enter the STAT mode.2. Enter your list of numbers for x, and press the "=" button.3. Press the "A+B" button to add all the numbers in the list.4. Press the "÷" button, followed by the number of elements in the list (in this case 6).5. Press the "=" button, which will give you the mean of x.6. Enter the list of numbers for x again.7. Press the "–" button to subtract the mean from each element in the list.8. Press the "=" button to get the result.
Related to [991es+] how to calc: (xi - meanX) ?
1. What does (xi - meanX) represent in a calculation?
(xi - meanX) represents the difference between a specific data point (xi) and the mean of all the data points (meanX) in a set of data. This is often used in statistical analysis to determine the deviation of a data point from the average.
2. How do I calculate (xi - meanX) using a scientific calculator like 991es+?
To calculate (xi - meanX) using a scientific calculator like 991es+, you can use the "x̅" button followed by the subtraction key "-" and then enter the specific data point (xi) you want to calculate. The calculator will automatically subtract the mean (meanX) from the data point and give you the result.
3. Why is (xi - meanX) important in statistical analysis?
(xi - meanX) is important in statistical analysis because it helps to measure the variability or spread of a set of data. By calculating the difference between each data point and the mean, we can determine how much the data points vary from the average and make conclusions about the data set.
4. Can (xi - meanX) be a negative number?
Yes, (xi - meanX) can be a negative number. This indicates that the data point is below the mean and has a negative deviation from the average. A positive number would indicate that the data point is above the mean and has a positive deviation from the average.
5. How can (xi - meanX) be used to identify outliers in a data set?
(xi - meanX) can be used to identify outliers in a data set by looking at the values with the largest positive or negative deviations from the mean. These extreme values can be considered outliers and may have a significant impact on the overall data set. By calculating (xi - meanX), we can easily identify these outliers and determine their effect on the data.
  • Differential Geometry
