A 1 500kg satellite is in orbit 250km above earth's surface.
The total energy is not conserved in this case.In summary, the question is asking for the minimum additional energy needed to place a 1,500kg satellite in a new stable orbit 800km above Earth's surface. The formula -GMm(1/r2-1/r1) is used to calculate the change in potential energy when changing altitude, but it is necessary to also consider the change in kinetic energy. The correct formula is -GMm((1/r2)-(1/r1)), and this will give the correct answer. Total energy is only conserved when an object changes altitude due to forces acting on it, but if the change is caused by an external agent, the total energy will change.
jakeginobi
A 1 500kg satellite is in orbit 250km above Earth's surface. What minimum additional energy is needed to place this satellite in a new stable orbit 800km above Earth's surface?
W = delta Ep = -GMm(1/r2-1/r1)
Ep = -GMm/r
Ek = GMm/2r or 1/2mv^2
I tried using the work formula = -GMm (1/2r2-1/2r1, but I get the wrong answer. The answer is 3.41 x 10^9J. I thought to change the radius of orbit from one to another is the change in potential energy which is work?
W = delta Ep is true if there is no change in kinetic energy.
TSny said:
The first part, W = delta Ep, is OK.
But, delta Ep = -GMm(1/r2-1/r1) is only true if there is no change in kinetic energy.
whenever an object radius of orbit is changed, there's a change in kinetic energy as well?
What if the object isn't in orbit, but a change in altitude? Would there be a change in kinetic too?
Yes.
That depends on how you change the altitude.
TSny said:
Yes.
For instance, in this question "An unpowered 1600kg object has an upward velocity of 7.0x10^3 m/s at an altitude of 100km above the earth. The object reaches a maximum altitude of 400km" would there be a kinetic energy change?
Actually, this formula does look like it should give you the correct answer if the expression is written as -GMm (1/(2r2)-1/(2r1)). I haven't tried plugging in numbers.
Note that the total energy is E = Ek + Ep. You stated that you can write Ek as GMm/(2r), although you left out the parentheses. Thus, you should be able to show that E = -GMm/(2r).
Yes. There is a change in kinetic energy if there is a change in speed. What is the speed at maximum altitude?
The speed at maximum altitude is zero, but I'm not sure why it is zero
However, you need to be careful with questions that ask you to calculate work. In particular, there is a difference between asking how much work you would have to do as compared to how much work the force of gravity does.
The work done by the force of gravity is always equal to the negative of the change in potential energy only. (Any change in kinetic energy is irrelevant.)
If the velocity is not zero, then the object is moving either upward or downward. Either way, the object cannot be at its maximum height. I'm assuming that the object is moving along a vertical line.
A fairly common error in these types of problems is to confuse "altitude of the orbit" with "radius of the orbit".
I get the correct answer using your formula given in post # 1. If you show your calculation with the numbers you used, we can see if there is a mistake in how you are using the formula.
I used -GMm(1/r - 1/r) so it's -6.67x10^-11(5.98x10^24kg)(1500kg)(1/7.18x10^6m - 1/6.63x10^6m)
which looks like the correct formula (except for some missing parentheses).
The question asks for the change in energy. This refers to the change in total energy, not just the change in potential energy.
TSny said:
OK. This is the wrong formula. In your first post you wrote which looks like the correct formula (except for some missing parentheses).
Oh alright thank you, I have one more question. Is total energy always conserved if you change altitudes if friction, or heat is neglected?
jakeginobi said:
I have one more question. Is total energy always if you change altitudes conserved if friction, or heat is neglected?
I would need to have more information.
For example, if the object is changing altitude because it is in an elliptical orbit and there are no forces other than gravity acting, then the total energy (Ek + Ep) is conserved.
But if the altitude is changed by some external agent (as in your exercise), then the work done by the external agent will cause the total energy of the object to change.
Related to A 1 500kg satellite is in orbit 250km above earth's surface.
1. How does the satellite stay in orbit?
The satellite stays in orbit by moving at a constant speed and direction, which is determined by the balance between the gravitational pull of the Earth and the satellite's own velocity. This balance is known as centripetal force.
2. What keeps the satellite from falling back to Earth?
The satellite's upward motion, coupled with the Earth's gravitational pull, creates a continuously curved path that keeps the satellite in orbit. This is known as an elliptical orbit.
3. How fast is the satellite moving in orbit?
The satellite is moving at a speed of approximately 7.8 kilometers per second in its orbit around the Earth.
4. How long does it take for the satellite to complete one orbit?
The time it takes for the satellite to complete one orbit, also known as its orbital period, depends on the altitude of the orbit. In this case, with an altitude of 250km, the satellite would complete one orbit in approximately 90 minutes.
5. What factors affect the satellite's orbit?
The main factors that affect a satellite's orbit are its altitude, speed, and the gravitational pull of the Earth. Other factors such as atmospheric drag and gravitational forces from other objects in space can also have an impact on the satellite's orbit.
