A 1600 kg jet engine is fastened to the fuselage of a passenger jet
In summary, the force on each bolt of a 1600 kg jet engine is 5226.67 N as the plane waits in line for clearance to take off, and 6293.33 N as the plane encounters turbulence during flight with an upward vertical acceleration of 2.0 m/s^2. This is due to the acceleration of the plane adding to the gravitational force on the engine.
sb13
A 1600 kg jet engine is fastened to the fuselage of a passenger jet by just three bolts (this is the usual practice). Assume that each bolt supports one-third of the load. (a) Calculate the force on each bolt as the plane waits in line for clearance to take off. (b) During flight, the plane encounters turbulence, which suddenly imparts an upward vertical acceleration of 2.0 m/s2 to the plane. Calculate the force on each bolt now.
F= ma
I got the correct solutions for both (a) and (b)
(a) F=ma= (1600 kg)(9.8 m/s^2) = 15680 N/3= 5226.67 N
(b) F=ma= (1600 kg)(9.8 m/s^2 + 2.0 m/s^2) = 18880 N/3 = 6293.33 N
But on (b), I don't understand why the acceleration of gravity was added to the upward vertical acceleration of 2.0 m/s^2, isn't gravity pulling the plane down, and the 2.0 m/s^2 pulling it up, shouldn't it be 9.8-2.0?
Because the plane is accelerating upward, the engine 'weighs' more due to its acceleration upward. The force due to an acceleration is in the opposite direction of the acceleration.
Ok. So the gravitational force ends up creating a greater force and because the acceleration is going upward, it is causing more force as well? What is the acceleration was -2.0 m/s^2 and the plane was being pulled downward, what effect would that have on the engine's force?
Think about this, when an elevator is accelerating upwards you feel heavier. The elevator is pulling you upwards but you feel a stronger downward force. Similarly when the elevator is accelerating downwards you feel lighter.
If the plane is accelerating downward, then the force due to acceleration points upward. The gravitational force is the same. It's the force due to acceleration of the plane that causes the change in the load of the bolts.
Gravitational force exists and is the same whether the plane is moving or stopped. The acceleration of the plane either adds to it or subtracts from it.
Related to A 1600 kg jet engine is fastened to the fuselage of a passenger jet
1. How does the weight of the jet engine affect the passenger jet's performance?
The weight of the jet engine is a critical factor in determining the performance of a passenger jet. As the engine is fastened to the fuselage, it adds to the overall weight of the aircraft. This weight must be carefully balanced with other components, such as the fuel and payload, to ensure safe and efficient flight. A heavier engine may require more fuel to lift off and maintain altitude, which can impact the range and speed of the aircraft.
2. What is the average weight of a jet engine used in passenger jets?
The average weight of a jet engine used in passenger jets is approximately 1600 kg, although this can vary depending on the size and type of the aircraft. For example, larger commercial jets may have engines that weigh up to 5000 kg, while smaller regional jets may have engines weighing around 900 kg.
3. How is the jet engine attached to the fuselage of a passenger jet?
The jet engine is typically attached to the fuselage using a series of bolts and brackets. These are carefully designed and installed to withstand the extreme forces and vibrations generated by the engine during flight. The engine is also connected to the aircraft's electrical and fuel systems through these attachments.
4. What are the main components of a jet engine?
A jet engine is a complex piece of machinery that is responsible for generating the thrust needed to propel an aircraft forward. The main components of a jet engine include the compressor, combustor, turbine, and nozzle. These work together to compress air, mix it with fuel, ignite it, and then release it at high speeds to create thrust.
5. How is the speed of a jet engine measured?
The speed of a jet engine is typically measured in revolutions per minute (RPM). This indicates how fast the engine's rotors are spinning and is a key factor in determining the amount of thrust the engine can produce. The RPM can be adjusted by the pilot to control the speed and power of the engine, allowing for changes in altitude, airspeed, and other flight conditions.
