MHB A and solution are known find B matrix
  • Thread starter Thread starter TomSavage
    Matrix
TomSavage
I have the matrix of A
1 2 -1
2 -1 1
and i am asked if there is any B matrix that can make AB = 1-1
1 1
I assume that this is not possible because if we follow the law of Ax=B then {A}^{-1} * B =x and since matrix a is singular then it cannot be inverted and thus this operation is impossible. Am I wrong in thinking this?
1 2 -1
2 -1 1
1 1
Hi TomSavage! Welcome to MHB! ;)
I'm afraid that's not quite true.
We can solve
$$\begin{pmatrix}
1 &2 &-1\\
2 &-1 &1
\end{pmatrix}\begin{pmatrix}
b_{11}\\b_{21}\\b_{31}
\end{pmatrix} = \begin{pmatrix}
1\\1
\end{pmatrix}$$
can't we?
It is under determined so that it has infinitely many solutions.
We can solve it with Gaussian elimination and pick for instance:
$$\begin{pmatrix}
3/5\\1/5\\0
\end{pmatrix}$$
Similarly we can solve:
$$\begin{pmatrix}
1 &2 &-1\\
2 &-1 &1
b_{12}\\b_{22}\\b_{32}
-1\\1
\end{pmatrix}$$
Combining the result with the first solution we get:
$$\begin{pmatrix}
1 &2 &-1\\
2 &-1 &1
3/5 &0 \\1/5 &0 \\0 & 1
1 & -1\\1 & 1
\end{pmatrix}$$
There you go, a solution for $B$.
More generally, we can find a solution in the least-square sense with:
$$B=A^+ \begin{pmatrix}
1 & -1\\1 & 1
\end{pmatrix}$$
where $A^+$ is the Moore-Penrose pseudoinverse.
The wiki article also explains how we can use it to find all solutions.
We can solve
$$\begin{pmatrix}
1 &2 &-1\\
2 &-1 &1
1\\1
\end{pmatrix}$$
can't we?
$$\begin{pmatrix}
3/5\\1/5\\0
\end{pmatrix}$$
$$\begin{pmatrix}
1 &2 &-1\\
2 &-1 &1
-1\\1
\end{pmatrix}$$
$$\begin{pmatrix}
1 &2 &-1\\
2 &-1 &1
1 & -1\\1 & 1
\end{pmatrix}$$
1 & -1\\1 & 1
\end{pmatrix}$$
Hey, I now understand mostly everything but what I don't know is how you got the solutions for B31 and B32. Did you get the other 4 solutions from gauss jordan and then just put the other two in that satisfy the solution or is there a direct mathematical method to get them because wouldn't adding the (3X1) solution set into the (2x3) matrix mess things up?
Let me show you how to solve:
$$\begin{pmatrix}
1 &2 &-1\\
2 &-1 &1
1\\1
\end{pmatrix}$$
with Gaussian elimination.
Take the first row, multiply it with $-2$, and add it to the second row.
Consequently we get a new system that has the same solutions as the previous system.
The result is:
$$\begin{pmatrix}
1 &2 &-1\\
0 &-5 &3
1\\-1
\end{pmatrix}$$
Starting from the bottom, we pick $b_{31}=0$, and see what happens afterwards.
To solve the second equation, we need $b_{21}=\frac 15$ now.
Then we solve the first equation, using the values we found so far, and we can with $b_{11}=\frac 35$.
There you go. We found one of the infinite number of solutions: $(b_{11},b_{21},b_{31})=(\frac 35, \frac 15, 0)$.Alternatively, we might have started with $b_{21}=0$.
Then we need $b_{31}=-\frac 13$ to solve the second equation.
And finally $b_{11}=\frac 23$ to solve the first equation for the solution $(b_{11},b_{21},b_{31})=(\frac 23, 0, -\frac 13)$.
Note that these 2 solutions together 'span' the solution space.
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
