A ball launched on a imclined plane
  • Thread starter dannyggg2003
  • Tags
    Ball Plane
In summary, the conversation discusses a homework problem involving a cart rolling down an inclined plane at an angle to the horizontal. When the cart reaches a speed of V, a ball is launched perpendicular to the cart. The question is whether the ball will land in the funnel, to the right of the funnel, or to the left of the funnel when it returns to the same initial perpendicular distance above the track. The equations used to solve this problem are the equations for displacement in the x and y directions. The attempt at a solution involves determining the displacement of the ball and the cart using these equations and comparing them to determine the final position of the ball. Clarification is needed on whether the ball is launched perpendicular to the ground or to the cart
dannyggg2003
The cart is rolling down an inclined plane which is at an angle  to the horizontal.
When the cart’s speed is V, the ball is launched. When the ball returns to the same initial perpendicular distance above the track, does it land in the funnel, to the right of the funnel, or to the left of the funnel?
yf = yi + Viy*t + 1/2ay*t^2
xf = xf + Vix*t + 1/2ax*t^2
I was thinking then the Xball would be something like
Xf ball = Vix(ball)*t + V(launch x) * t
Xf car = Vix(car)*t + 1/2(gx)t^2
Vix ball / car are equal...so in this case i have to determine whether V(launch x) * t is larger or 1/2(gx)t^2 is larger...there were no numbers given so i and very confused right now thinking maybe my attempt is on the wrong track, can someone help me?
Is the ball launched perpendicular to the ground(x axis) or to the cart(inclined plane)?
FAQ: A ball launched on a imclined plane
What is an inclined plane?
An inclined plane is a flat surface that is tilted at an angle, allowing objects to move along it with less effort than if they were on a flat surface.
What is the purpose of launching a ball on an inclined plane?
The purpose of launching a ball on an inclined plane is to study the effects of gravity and friction on the motion of the ball. It can also be used to demonstrate the concept of potential and kinetic energy.
How does the angle of the inclined plane affect the motion of the ball?
The angle of the inclined plane affects the motion of the ball by changing the amount of force needed to move the ball up the incline. The steeper the angle, the more force is required to overcome gravity and friction.
What factors can influence the distance the ball travels on the inclined plane?
The factors that can influence the distance the ball travels on the inclined plane include the angle of the incline, the initial velocity of the ball, the mass and size of the ball, and the surface of the inclined plane (friction).
How does the motion of the ball on an inclined plane relate to real-life situations?
The motion of the ball on an inclined plane relates to real-life situations in which objects are moving on surfaces with varying angles, such as a car driving up a hill or a rollercoaster going up and down slopes. It also helps us understand the forces acting on objects in motion and how they affect their movement.
