A bar spinning with unlimited angular velocity
In summary, a theoretical question was posed about a bar spinning with unlimited angular velocity. The conversation discussed the possibility of the bar emitting x-rays and gamma rays as well as the heating up of the bar due to friction with air or in the axle. The concept of mixing mechanical waves with electromagnetic waves was also addressed. It was suggested that the bar would generate a magnetic field due to spin charge alignment, but this was met with skepticism. The conversation also touched on the effects of the bar's angular velocity approaching the speed of light, with the conclusion being that this is not possible as angular speed and linear speed are different quantities. There are still some points that need to be clarified before a definitive answer can be given.
d4rr3n
53
Theoretical question about a bar spinning with unlimited angular velocity.
Lets imagine we have a bar of indestructible metal and we attach this bar onto a motor which is capable of an infinite number of rpm. We have a dial next to the motor that allows us to increase the rpm of the motor. We start the motor off and gradually increase the rpm.
First a low pitch hum is heard coming from the rotating bar which is attached at right angles to the motor shaft so that the center of the bar is in line with the center of rotation of the motor shaft. This hum gradually increases in pitch as the motor speeds up until it is a high pitch sound then at a frequency above human hearing. It is noted that the bar starts to heat up as it spins rapidly, first only an infrared camera can pick it up but soon the bar is glowing a dull red, then a cherry red, then orange, yellow, blue and then it is white hot.
As you can see we started with low frequency sound waves then to high frequency sound waves then onto low frequency infrared electromagnetism and went through the spectrum until it was glowing white hot.
My question is will the bar go on to emit x-rays and eventually gamma rays and would it at any point emit radio or microwaves
If the temperature is high enough, yes. Just plug the temperature int the black body formula and look at the peak of the spectrum.
You are mixing up the mechanical waves with the electromagnetic waves. The IR waves are not a continuation of the high frequency sound waves. They are different phenomena. If for some reason the bar produces sound waves, there is no reason to assume that these will be replaced by EM waves above some frequency.
And why would the ideal bar in the ideal experiment heat up? Friction with air or in the axle? Or you are looking at a different mechanism? The acceleration of charges in the bar?
Yes. The model needs to be defined better; just how 'ideal' are you wanting to be? Unlimited rotation speed implies no atmosphere around it so no sound, for a start and no increase in temperature. A relatively modest tip speed in air at sea level would produce a temperature of several thousand K. (Consider the temperature of impacting meteorites) So we're not talking in terms of unlimited speed - just 'high' speed.
I am aware that sound waves are not electromagnetic however it is a well known fact to anyone who has played with a motor as a kid that increased rpm results in increased sound pitch. It is also a fact that a object spinning in an atmosphere will heat up, infrared is electromagnetic as is all the other colored lights emitted by the glowing bar.
I suspect the bar would heat up even in the vacuum of space if spun fast enough. First the spinning bar should generate a magnetic field due to spin charge alignment
I allowed unlimited speed so that nobody could say we can't spin it fast enough or there is no motor that could do that ;)
What would happen to the bar as its angular velocity approached the speed of light for example, I'm sure the effect of spin would result in a different phenomena then an object traveling in a straight line approaching the speed of light.
I don't know of any physics by which a neutral spinning bar generates a magnetic field. I hope this isn't a relativistic effect. And could you kindly outline the mechanism by which the bar would heat up even in the vacuum of space.
The angular speed cannot approach the speed of light. Or any other linear speed.
They are different quantities with different units. Does not make sense to compare them.
I am afraid this may be just one of the points you need to clarify (at least for yourself).
Also, what do you mean by "spin charge alignment"?
By "spin" you mean the macroscopic spin of the bar or the microscopic quantity, the spin of the electron?
Before you can think about an answer you need to understand the question. I am afraid we are not there yet.:)
Related to A bar spinning with unlimited angular velocity
1. What is meant by "unlimited angular velocity"?
Angular velocity refers to the rate at which an object rotates around a fixed axis. When we say "unlimited angular velocity", it means that the bar is spinning at a constant speed without any limits or restrictions.
2. Is it possible for a bar to spin with unlimited angular velocity?
In theory, yes. However, in reality, it is not possible for a bar to spin with unlimited angular velocity. This is because there are physical limitations such as air resistance and friction that will eventually slow down the bar's rotation.
3. What factors can affect the angular velocity of a spinning bar?
The angular velocity of a spinning bar can be affected by various factors such as the length and weight of the bar, the force applied to it, and any external forces acting on it, such as air resistance or friction.
4. How does unlimited angular velocity affect the stability of the bar?
With unlimited angular velocity, the bar will continue to spin at a constant speed without slowing down. This can make the bar unstable as it may become difficult to control or balance. Additionally, the high velocity may also cause the bar to become deformed or break due to the centrifugal force acting on it.
5. What applications or real-world examples involve a bar spinning with unlimited angular velocity?
One possible example is a centrifuge, which uses high-speed rotation to separate different components of a substance. Another example could be a gyroscope used in navigation or stabilizing devices. However, in both cases, the angular velocity may not be truly unlimited as there are still physical limitations and safety considerations involved.
  • Mechanical Engineering
