A Beginner's Guide to the Squeeze Theorem
  • MHB
  • Thread starter karush
  • Tags
    Theorem
In summary, the squeeze theorem can be used to show that $\lim_{n \to \infty} \frac{n!}{n^x} = 0$ by observing that the denominator is increasing faster and using the upper bound of $\frac{1}{n}$ which converges to 0.
karush
MHB
3,269
Use the squeeze theorem to show that
$\displaystyle
\lim_{{n}\to{\infty}} \frac{n!}{{n}^{x}}=0 \\
\text{have never used the squeeze theorem } \\
\text{but by observation the denominator is increasing faster}$
Re: Squeeze theorm
$\displaystyle
What information is given about $x$ ?
Re: Squeeze theorm
$\displaystyle
\lim_{{n}\to{\infty}} \frac{n!}{{n}^{n}}=0 \\
\text{sorry typo} $
Re: Squeeze theorm
It holds that if $\sum a_n$ converges, then $\lim_{n \to +\infty} a_n=0$.
Can you check if $\sum_{n=1}^{\infty} \frac{n!}{n^n}$ converges?
The problem asked to prove the limit using the squeeze theorem. In a calculus course limits of sequences (including the squeeze theorem) may come before series.
We have
\begin{multline}
0\le\frac{n!}{n^n}=
\frac{n\cdot(n-1)\cdot\ldots\cdot\left(\lfloor n/2\rfloor+1\right)}{n\cdot n\cdot\ldots\cdot n}\cdot\frac{\lfloor n/2\rfloor\cdot\left(\lfloor n/2\rfloor-1\right)\cdot\ldots\cdot1}{n\cdot n\cdot\ldots\cdot n}
\le 1\cdot\left(\frac{1}{2}\right)^{\lfloor n/2\rfloor}
\end{multline}
The sequence $(1/2)^{\lfloor n/2\rfloor}\to0$ as $n\to\infty$ (this can be proved by definition). Therefore, the original sequence is squeezed between two sequences whose limit is 0.
As Deveno pointed out, an even simpler upper bound is
\dfrac{n!}{n^n} = \dfrac{1}{n}\cdot\dfrac{2}{n} \cdots\dfrac{n}{n} \leq \dfrac{1}{n}\cdot 1\cdots 1 = \dfrac{1}{n},
and it is known that $1/n\to0$ as $n\to\infty$.
Ok, I see how this works now... was quite a bit more understandable than book examples.
FAQ: A Beginner's Guide to the Squeeze Theorem
What is the Squeeze Theorem?
The Squeeze Theorem, also known as the Sandwich Theorem or the Pinching Theorem, is a mathematical principle that is used to determine the limit of a function by comparing it to two other functions that are known to have the same limit.
Why is the Squeeze Theorem useful?
The Squeeze Theorem is useful because it provides a way to evaluate the limit of a function that may be difficult or impossible to evaluate directly. It also allows us to prove the limit of a function by using the limits of simpler functions.
How do you use the Squeeze Theorem?
To use the Squeeze Theorem, you need to find two functions that "squeeze" the original function and have the same limit as the original function. You then take the limit of these two functions, and if they have the same limit, then the limit of the original function also exists and is equal to that limit.
What are the conditions for using the Squeeze Theorem?
The Squeeze Theorem can be used if the functions involved are continuous and the limit of the "squeezing" functions is known or can be easily determined. Additionally, the "squeezing" functions must be greater than or equal to the original function (for upper bound) or less than or equal to the original function (for lower bound).
Can the Squeeze Theorem be extended to multivariable functions?
Yes, the Squeeze Theorem can be extended to multivariable functions by using a similar principle of finding two functions that "squeeze" the original function and have the same limit. However, in this case, the "squeezing" functions must approach the same point in the multivariable function's domain.
