A bit confused about this variation
In summary, a derivation of the Noether theorem has been presented where the transformation of the time and configuration space are written in terms of an infinitesimal parameter ##\varepsilon## and generators ##\delta t## and ##\delta q^a##, representing time evolution and generalized coordinates, respectively. By using Taylor expansion and letting ##\varepsilon \to 0##, it can be shown that the variation of the Lagrangian ##\delta \mathcal{L}## is given by the chain rule of multivariable calculus. This leads to the conclusion that if ##\delta \mathcal{L} = \dot{F}##, for some transformation that is a quasi-symmetry,
etotheipi
I came across a derivation of the Noether theorem with a step I don't understand; the transformation of the time and configuration space are written as$$\tau(t,\varepsilon) = t + \varepsilon \delta t, \quad Q^a(q,\varepsilon) = q^a + \varepsilon \delta q^a$$here ##\varepsilon## is an infinitesimal parameter, whilst it looks like ##\delta t## and ##\delta q^a## are in this notation the generators of the time evolution and generalised coordinates respectively. Then they write$$\varepsilon \delta \mathcal{L} = \mathcal{L}(Q(q,\varepsilon), \dot{Q}(q,\varepsilon), \tau(t,\varepsilon)) - \mathcal{L}(q,\dot{q}, t)$$ $$\delta \mathcal{L} = \frac{\partial \mathcal{L}}{\partial q^a} \delta q^a + \frac{\partial \mathcal{L}}{\partial \dot{q}^a} \delta \dot{q}^a + \frac{\partial \mathcal{L}}{\partial t} \delta t$$and from this we can go on to show that if ##\delta \mathcal{L} = \dot{F}## i.e. for some transformation that is a quasi-symmetry, then ##J = \mathcal{H} \delta t - p_a \delta q^a + F## is a constant of the motion.
I don't understand the third line, where does it come from? It's not the chain rule of multivariable calculus, because the generators ##\delta q^a## and ##\delta t## for instance are finite. Maybe I misunderstand how the author has defined the variation of a function in this case. I wondered if someone could help out? Thanks!
Likes JD_PM
It is indeed the chain rule of multivariable calculus, just use Taylor expansion arround ##\varepsilon = 0## in
And then let ##\varepsilon \to 0##. From where follows
Likes JD_PM and etotheipi
Thanks, do you mean something like, let$$F(\varepsilon) = \mathcal{L}(q + \varepsilon \delta q, \dot{q} + \varepsilon \delta \dot{q}, t + \varepsilon \delta t)$$then$$
\begin{align*}
F(\varepsilon) &= \mathcal{L}(q, \dot{q},t) + \varepsilon \left[ \frac{d\mathcal{L}(q + \varepsilon \delta q, \dot{q} +\varepsilon \delta \dot{q}, t + \varepsilon \delta t)}{d\varepsilon} \right]_{\varepsilon = 0} + \mathcal{O}(\varepsilon^2) \\
\varepsilon\left[
\frac{\partial \mathcal{L}}{\partial (q + \varepsilon \delta q)}\frac{d(q + \varepsilon \delta q)}{d\varepsilon} + \frac{\partial \mathcal{L}}{\partial (\dot{q} + \varepsilon \delta \dot{q})}\frac{d(\dot{q} + \varepsilon \delta \dot{q})}{d\varepsilon} + \frac{\partial \mathcal{L}}{\partial (t + \varepsilon \delta t)}\frac{d(t + \varepsilon \delta t)}{d\varepsilon} \right]_{\varepsilon = 0} + \mathcal{O}(\varepsilon^2) \\
\frac{\partial \mathcal{L}}{\partial (q + \varepsilon \delta q)}\delta q + \frac{\partial \mathcal{L}}{\partial (\dot{q} + \varepsilon \delta \dot{q})} \delta \dot{q} + \frac{\partial \mathcal{L}}{\partial (t + \varepsilon \delta t)} \delta t\right]_{\varepsilon = 0} + \mathcal{O}(\varepsilon^2)
\end{align*}$$And this implies that$$\begin{align*}
\delta \mathcal{L} &= \frac{1}{\varepsilon} \left[ \mathcal{L}(Q(q,\varepsilon), \dot{Q}(q,\varepsilon), \tau(t,\varepsilon)) - \mathcal{L}(q,\dot{q}, t) \right] \\
&= \frac{\partial \mathcal{L}}{\partial q}\delta q + \frac{\partial \mathcal{L}}{\partial \dot{q}} \delta \dot{q} + \frac{\partial \mathcal{L}}{\partial t} \delta t
\end{align*}$$as we let ##\varepsilon \rightarrow 0## so that the ##\mathcal{O}(\varepsilon)## terms drop out.
Likes JD_PM
Yeah, essentially note that
$$\left.\frac{\partial \mathscr{L}(q+\varepsilon \delta q)}{\partial (q + \varepsilon \delta q)}\right|_{\varepsilon=0} = \frac{\partial \mathscr{L}(q)}{\partial q}$$
Where is this derivation from? I'm a bit surprised that they don't consider the action,
$$S'=\int \mathrm{d} t' L(q',\dot{q}',t')=\int \mathrm{d} t \frac{\mathrm{d} (t+\epsilon \delta t)}{\mathrm{d} t} L(q',\dot{q}',t').$$
and why they don't carefully define
$$\delta \dot{q}=\frac{\mathrm{d} q'}{\mathrm{d} t'}-\frac{\mathrm{d} q}{\mathrm{d} t} = \frac{\mathrm{d} (q+\epsilon \delta q)}{\mathrm{d} t} \left (\frac{\mathrm{d}(t+\epsilon \delta t)}{\mathrm{d} t} \right)^{-1} -\frac{\mathrm{d} q}{\mathrm{d} t}=\epsilon \frac{\mathrm{d}}{\mathrm{d} t} \delta q-\epsilon\frac{\mathrm{d}q}{\mathrm{d} t} \frac{\mathrm{d} \delta t}{\mathrm{d} t} + \mathcal{O}(\epsilon^2).$$
This one is from Chapter 10 section 10.2.4 of Orodruin's book, in the section on the classical mechanics :smile:
Likes JD_PM
On p. 623 he restricts himself to pure time translations, i.e., ##\delta t=1=\text{const}##, which explains why he doesn't need to consider the complications of the more general case that ##\delta t## is a function of the ##q## and ##t## (which you need for special relativity and the Poincare symmetry but usually not for Newtonian physics and Galilei symmetry).
Thanks! I did find just now the section in your classical mechanics notes (https://itp.uni-frankfurt.de/~hees/publ/theo1-l3.pdf) on page 91 where the Noether theorem is also derived, so I'll read through that as well! It's in German but there is a high density of equations! ☺
Likes JD_PM and vanhees71
Related to A bit confused about this variation
1. What is variation in scientific terms?
Variation refers to the differences or diversity that exists within a population or species. It can be observed in physical characteristics, behavior, or genetic makeup.
2. What causes variation?
Variation can be caused by a combination of genetic and environmental factors. Genetic variation occurs through mutations and recombination of genes during reproduction. Environmental factors such as diet, climate, and exposure to different stimuli can also influence variation.
3. How is variation important in scientific research?
Studying variation is crucial in understanding the diversity of life and how organisms adapt to different environments. It also helps in identifying genetic diseases and developing treatments, as well as studying the effects of environmental changes on a population.
4. What are the different types of variation?
There are three main types of variation: genetic, environmental, and phenotypic. Genetic variation refers to differences in DNA sequences between individuals. Environmental variation is caused by external factors and can be temporary or permanent. Phenotypic variation is the observable differences in physical characteristics among individuals.
5. How can we measure and analyze variation?
Variation can be measured and analyzed through statistical methods such as standard deviation, variance, and correlation. These methods help in quantifying the degree of variation within a population and identifying patterns or relationships between different variables.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
