A body on a table with friction.
In summary, the block is moving with a constant speed and the coefficient of kinetic friction between the block and the table is 0.560. To move with a constant speed, m3 should be 0.2232.
dttah
37
Hello, I'd like to know if this is correct ... thank you.
You are given that the coefficient of kinetic friction between the block and the table in the attachment is 0.560, and m1 = 0.135 kg and m2 = 0.260 kg. (a) What should m3 be if the system is to move with a constant speed? (Assume ideal conditions for the string and pulleys.)
Start by writing down all of the forces involved in m1 and m2...
[itex]\Sigma F_{m1} = T_1 - m_1g = m_1a
[/itex]
[itex]
\Sigma F_{m2} = T_2 - m_2g = m_2a
[/itex]
[itex]
\Sigma F_{m3} = T_2 - T_1 - \mu m_3g = 0
[/itex]
I write = 0 because constant speed means no acceleration... so no acceleration means that F = ma => F = 0.
Now I have to solve this thingy, solve for T1 And T2 in the first two and stick it in the third.. getting..
[itex]
T_1 = m_1g + m_1a
[/itex]
[itex]
T_2 = m_2g + m_2a
[/itex]
[itex]
m_2g + m_2a - m_1g - m_1a - \mu m_3g = 0
[/itex]
Okie dokie, now we are able to solve for m3...
[itex]
m_3 = \frac{m_2g + m_2a - m_1g - m_1a}{\mu g} \rightarrow \frac{m_2g - m_1g}{\mu g}[/itex]
[itex]
\frac{1,225}{5.488} = 0.2232[/itex]
Looks good. A few comments:
dttah said:
[itex]
T_1 = m_1g + m_1a
[/itex]
[itex]
T_2 = m_2g + m_2a
[/itex]
Since a = 0, you should immediately write T1 = m1g and T2 = m2g.
[itex]
Good, but cancel those g's. The more you can cancel and simplify before reaching for the calculator the better.
The result looks good.
Note that certain shortcuts present themselves when you are given that velocity is constant; Since there's no acceleration your formulas for the tensions can simplify accordingly. No need to carry any acceleration terms after that point. The net horizontal force on m3 is then just the difference in the tensions.
Yeah, I noticed I had to write a = 0 just afterwards and I was too lazy to correct all the latex. Good point about the g's, will do next time. Thank you! ;)
kg
Hello! Your approach and calculations seem to be correct. However, it would be helpful if you could provide some context or additional information, such as a diagram or description of the setup, to make it easier to understand the problem and your solution. Also, it's always a good idea to double check your units and make sure they are consistent throughout your calculations. Keep up the good work!
Related to A body on a table with friction.
1. What is friction?
Friction is a force that resists the motion of an object when it comes into contact with another surface. It can be caused by the microscopic roughness of surfaces rubbing against each other.
2. How does friction affect a body on a table?
Friction can affect the motion of a body on a table by impeding its movement and causing it to slow down or stop. It can also cause the body to slide or tilt if the force of friction is greater than the force moving the body.
3. What factors affect the amount of friction on a body on a table?
The amount of friction on a body on a table can be affected by the weight and surface area of the body, the type of surface it is in contact with, and the amount of force applied to the body.
4. How is friction measured?
Friction is typically measured by the coefficient of friction, which is the ratio of the force of friction to the normal force (perpendicular force) between two surfaces. It can also be measured by the amount of force required to move an object across a surface.
5. Can friction be reduced on a body on a table?
Yes, friction can be reduced on a body on a table by using lubricants between the surfaces, increasing the smoothness of the surfaces, or reducing the weight or surface area of the body. However, it cannot be completely eliminated as it is a natural force that occurs whenever two surfaces are in contact.
