A bullet is shot into a block of wood
In summary: You can then figure out what speed the bullet must have had initially (using the bullet's mass and the angular speed you just calculated), and what its energy was.Your "stage 0" is the moment just before the bullet strikes the block -- the bullet's speed is the unknown.Your "stage 1" is the moment just after the bullet has come to rest in the block. The block+bullet are momentarily at rest, and the rod is just starting to rotate. The bullet's energy has been transferred to the block+bullet+rod+Earth system.Your "stage 2" is the moment when the block+bullet+rod are at the lowest point of their swing. The bullet's energy has been
pdonovan
1. A 2.3kg wood block hangs from the bottom of a 1.0kg, 1.2m long rod. The block and rod form a pendulum that swings on a frictionless pivot at the top end of the rod. A 10g bullet is fired into the block, where it sticks, causing the pendulum to swing out to a 33degree angle.
Angular momentum of a particle = mvr^2
Angular momentum of a rigid body = Iw
Conservation of angular momentum: Li = Lf
Conservation of energy: Ei = Ef
I have 3 stages set up. 0, which is right before the bullet hits the wood. 1, when the bullet is embedded into the wood and hasn't traveled anywhere yet. 2, when the pendulum has fully swung out.
L0 = L1
(Mbullet)(Vbullet)(R^2) = (Ibullet)(Wbullet) + (Iwood)(Wwood)
(.0144)(Vbullet) = 3.3242w
E1 = E2
(.5)(Ibullet)(w^2) + (.5)(Iwood)(w^2) = (Mbullet)(g)(h) + (Mwood)(g)(h) + PErod
I think the main issue is that I don't know what the potential energy of the rod is, but there certainly may be other issues. I believe h = .194m.
Any help is greatly appreciated!
If anyone sees any minor errors in my calculations (or major!) please please help, I'm trying to figure this out before a test. Thank you.
Is there some reason why you don't specify the units of the quantities? What's a "1.0 , 1.2--long rod"? Is a "10 bullet" a 10 kilogram bullet? 10 pound? 10 ton? Is a 33 angle 33 degrees, or perhaps 33 grads, or 33 radians (lots of revolutions!)? Marks are lost when units are ignored.
Also, you didn't state what the goal of the question is. What's to be calculated?
Sorry for the lack of units, the question was copy pasted.
So, what is it that you're trying to calculate?
The initial speed of the bullet.
The angular momentum of a massive particle about a center is mvr, not mvr2.
You can calculate the PE of the rod+block+bullet by considering the elevation of the centers of mass of the rod and the block + bullet combination. (Figure out the Δh's when they're at the 33° position).
If you equate the PE with the mechanical energy (rotational in this case) when the rod+block+bullet is at its lowest point, you can determine the angular velocity there, and hence the angular momentum of the ensemble. The bullet must have supplied this angular momentum.
Related to A bullet is shot into a block of wood
What is the purpose of shooting a bullet into a block of wood?
The purpose of shooting a bullet into a block of wood is to study the effects of the bullet's impact on the wood. This can provide valuable information for understanding ballistics and improving safety measures.
What happens to the bullet when it hits the block of wood?
When the bullet hits the block of wood, it will penetrate into the wood and potentially fragment or deform. The amount of penetration and damage will depend on factors such as the bullet's velocity, shape, and material, as well as the density and hardness of the wood.
How does the density of the wood affect the bullet's impact?
The density of the wood can have a significant impact on the bullet's penetration and damage. A denser wood will be more resistant to the bullet, resulting in less penetration and potentially more damage to the bullet. On the other hand, a less dense wood may allow the bullet to penetrate further and cause less damage.
What can shooting a bullet into a block of wood tell us about the bullet's trajectory?
By analyzing the bullet's penetration and damage patterns on the wood, scientists can gather information about the bullet's trajectory and potential range. This can be helpful in understanding the bullet's flight and improving accuracy.
Can shooting a bullet into a block of wood simulate real-life scenarios?
While shooting a bullet into a block of wood can provide valuable data, it is not an exact simulation of real-life scenarios. Factors such as air resistance, target movement, and impact on different materials can affect the bullet's behavior in ways that may not be fully captured in this experiment.
