MHB A center of mass determined triangle: Find the angles of the triangle P_1P_2P_3
The problem involves three masses located at points on a circle, with their center of mass at the circle's center. The masses are $m$, $2m$, and $\sqrt{3}m$, positioned at points $P_1$, $P_2$, and $P_3$. To find the angles of triangle $P_1P_2P_3$, the relationship between the masses and their positions is crucial. The solution involves applying principles of equilibrium and geometry to derive the angles based on the given mass distribution. Ultimately, the angles can be determined through trigonometric relationships derived from the mass ratios.
lfdahl
MHB
Masses $m, 2m$ and $\sqrt{3}m$ are located at points $P_1, P_2$ and $P_3$ on a circle $C$
so that their center of mass coincides with the center of $C$.
Find the angles of the triangle $P_1P_2P_3$.
Mathematics news on Phys.org
Here´s the suggested solution:
Let $C$ be the unit circle of the $xy$-plane, with mass $m$ at the point $(1; 0)$.
If \[\angle P_1OP_2 = \alpha, \: \: \: \angle P_1OP_3 = \beta\] – then\[m\cdot 0+2m\sin \alpha +\sqrt{3}m\sin \beta = 0\: \: \: \: (1). \\ m\cdot 1 +2m\cos \alpha +\sqrt{3}m\cos \beta = 0\: \: \: \: (2).\]From $(1)$: \[\frac{\sin \alpha }{\sin \beta }= -\frac{1}{2}\sqrt{3}\]substitute in $(2)$ and obtain\[1 + 2 \cos \alpha +\sqrt{3}\sqrt{1-\frac{4}{3}\sin^2\alpha } = 0,\]whence\[\cos \alpha = -\frac{1}{2}, \: \: \alpha = 120^{\circ}.\]so that\[\sin \beta = -1, \: \: \beta = 270^{\circ}.\]Thus, the angles of $\bigtriangleup P_1P_2P_3$ are: $45^{\circ}, 60^{\circ}, 75^{\circ}$.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 59 ·
37K
