A charged conducting wire in an electric field
In summary, when there is a wire with a net charge in a uniform electric field, the electric field inside the wire is zero due to the movement of charges to cancel it out. The principle of superposition can be used to solve for the electric field surrounding the wire by combining the solutions for a wire without net charge and a non-neutral conductor wire without the external field. The charge distribution along the wire will be q1 except at the ends, where it will be q1-q2 and q1+q2, canceling out the external field. The geometry of the wire is also an important factor to consider.
cosmo123
24
Suppose I have a wire with a net charge (lets say negative) in a uniform electric field from another source, such that the field lines are parallel to the wire. I want to work out the electric field surrounding the wire.
Because the wire is conducting, the electric field inside the wire will be zero, because the electric field in the wire causes the charges in the wire to move to cancel it out. Because the exterior electric field also moves the charges around in the wire, this means i can't just add on the field around the wire in equilibrium to the surrounding exterior electric field. I am assuming the charges in the wire get pushed up to each end, but I can't figure out by how much or what field this produces. Any help?
First off, you would definitely need to know the geometry of this wire. Next, the beauty of working with conductors is the ease of the principle of superposition. Basically, solve the problem of the wire without net charge and the electric field and the problem of a non-neutral conductor wire without the external field. Since both solve Poisson's equation with the same boundary conditions (field is zero in the conductor), the solution to your problem is the superposition of those two.
If your initial charge distribution is q1, you will have q1 all along the wire except at the ends you will have q1-q2, and q1+q2 at opposites sides where the charges +/-q2 cancel the external field.
Related to A charged conducting wire in an electric field
1. What is a charged conducting wire?
A charged conducting wire is a material that has been given an excess or deficiency of electrons, resulting in an overall electric charge. This charge allows the wire to interact with electric fields and conduct electricity.
2. How does a charged conducting wire behave in an electric field?
A charged conducting wire will experience a force when placed in an electric field. The direction of the force depends on the direction of the electric field and the polarity of the charge on the wire.
3. What factors affect the behavior of a charged conducting wire in an electric field?
The behavior of a charged conducting wire in an electric field is affected by the strength and direction of the electric field, the amount and polarity of the charge on the wire, and the properties of the material the wire is made of.
4. How can a charged conducting wire be used in practical applications?
A charged conducting wire is used in many practical applications, such as in electronic circuits, power transmission lines, and sensors. It can also be used to create electric motors, generators, and other devices that utilize the interaction between electric fields and charged particles.
5. Can a charged conducting wire be neutralized in an electric field?
Yes, a charged conducting wire can be neutralized in an electric field by applying a force in the opposite direction of the electric field. This can be achieved by using a charged object with opposite polarity or by adjusting the properties of the wire, such as its length or material.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
