A charged particle entering a magnetic field at an angle -- is work done?
In summary, the conversation discusses the effects of a magnetic field on charged particles. It is noted that a purely magnetic field does not do work on a charged particle as the force is always perpendicular to the velocity. Even when the particle enters the field at an angle, the force remains perpendicular. This means that changing the motion of the particle does not necessarily require expending or gaining energy. An example of this is centripetal motion at a constant potential energy state.
big_bounce
102
Hello PF's members
I know a magnetic field doesn't work on charged particles if magnetic field being perpendicular to the velocity of the particles. also i know magnetic field doesn't work if a charged particle enters with right angle into the field.
But suppose that a charged particle like electron is entering with angel 35 degree at a uniform magnetic field.
Does magnetic field work on charged particle after entering and electron gains energy? what about when magnetic field is non-uniform?
A purely magnetic field never does work on the charged particle since the force is always perpendicular to the velocity,
$$\vec{F}_{\text{mag}}=\frac{q}{c} \vec{v} \times \vec{B} \; \Rightarrow \; P=\vec{v} \cdot \vec{F}=0.$$
Likes big_bounce
EVEN If the electron enters the field at an angle to the field direction, magnetic force remains perpendicular to the velocity?
Yes, the force is always perpendicular to both the field and the velocity.
Likes big_bounce
therefore for changing motion of object in direction we always don't have to expend (or gain) energy?
Think of a simple case of centripetal motion at some constant potential energy state (perhaps a "car" going around a circular, horizontal track at constant speed). The centripetal force is responsible for the change in motion, but that doesn't mean the energy changes (constant speed means constant kinetic energy).
Related to A charged particle entering a magnetic field at an angle -- is work done?
1. What is a charged particle?
A charged particle is an atom or molecule that has an imbalanced number of protons and electrons, resulting in a positive or negative charge.
2. What is a magnetic field?
A magnetic field is a region of space where a magnetic force can be detected. It is created by moving electric charges and can interact with other magnetic fields and charged particles.
3. What does it mean for a charged particle to enter a magnetic field at an angle?
When a charged particle enters a magnetic field at an angle, it means that the particle's path is not perpendicular to the direction of the magnetic field. The angle between the particle's path and the magnetic field is known as the angle of incidence.
4. Is work done when a charged particle enters a magnetic field at an angle?
Yes, work is done when a charged particle enters a magnetic field at an angle. This is because the magnetic field exerts a force on the particle, causing it to change direction and thus changing its kinetic energy.
5. How does the amount of work done on a charged particle entering a magnetic field at an angle depend on the angle of incidence?
The amount of work done on a charged particle entering a magnetic field at an angle depends on the sine of the angle of incidence. The greater the angle, the greater the amount of work done, as the force exerted by the magnetic field is perpendicular to the direction of the particle's motion.
  • Electromagnetism
