jianghan
- 25
A battery has an emf of 6v. The battery is connected in series with an ammeter and a voltmeter.If a certain resistor is connected in parallel with the voltmeter,the voltmeter reading decreases by a factor of 3,and the ammeter reading increases by the sme factor. What is the initial reading V of the voltmeter? All elements except battery in the circuit have unknown internal resistances
2. The attempt at a solution
R3 is the resistor that is connected in parallel with the voltmeter.
I also use R1,R2 to represent internal resistances of voltmeter and ammeter which i assume are resistors connected in series to the voltmeter and ammeter.(ammeter then measures current flowing through R2 while voltmeter measures pd across R1 or R3)
I tried to construct equations using basic rules about resistors connected in series or parallel,after solving some (overly complex) equations,i had V=4.8v while the answer is v=4.5v
I also tried to use Kirchhoff's rules to solve,but it did not work out.
