A Clausen function triplication formula
In summary, the triplication formula for the second order Clausen function can be proven by expanding it into a Fourier series and using the identity $\sin(3x) = 3\sin x - 4\sin^3 x$.
DreamWeaver
303
Define the second order Clausen function by:\(\displaystyle \text{Cl}_2(\varphi) = -\int_0^{\varphi} \log\Bigg| 2\sin \frac{x}{2} \Bigg|\, dx = \sum_{k=1}^{\infty}\frac{\sin k\varphi}{k^2}\)Prove the triplication formula:\(\displaystyle \text{Cl}_2(3\varphi) = 3\text{Cl}_2(\varphi) + 3\text{Cl}_2\left(\varphi+ \frac{2\pi}{3} \right) + 3\text{Cl}_2\left(\varphi+ \frac{4\pi}{3} \right)\)Hint:
Consider the triplication formula for the Sine:
\(\displaystyle \sin 3x = 3\sin x-4\sin^3 x\)
Mathematics news on Phys.org
Use the Fourier series.The triplication formula can be proven by starting with the Fourier series representation of the second order Clausen function:
\text{Cl}_2(\varphi) = \sum_{k=1}^{\infty}\frac{\sin k\varphi}{k^2}
We can then use the identity $\sin(3x) = 3\sin x - 4\sin^3 x$ to expand $\sin 3\varphi$ in terms of sines of multiples of $\varphi$. This leads to the following expression for $\text{Cl}_2(3\varphi)$:
\text{Cl}_2(3\varphi) = \sum_{k=1}^{\infty}\frac{3\sin k\varphi - 4\sin^3 k\varphi}{k^2}
By expanding the right-hand side of this equation into separate sums for each term, we can rearrange it to obtain the triplication formula:
FAQ: A Clausen function triplication formula
What is a Clausen function triplication formula?
A Clausen function triplication formula is a mathematical formula that expresses a relationship between the Clausen function and certain trigonometric functions. It is used in the field of mathematics to simplify complex calculations involving the Clausen function.
Who discovered the Clausen function triplication formula?
The Clausen function triplication formula was discovered by the Danish mathematician Thomas Clausen in the 19th century. It was published in his paper "De functionibus hypergeometricis" in 1832.
What is the purpose of the Clausen function triplication formula?
The Clausen function triplication formula is used to simplify calculations involving the Clausen function, which is a special function that arises in the study of mathematical series and integrals. It allows for more efficient and accurate calculations of complex mathematical problems.
How is the Clausen function triplication formula derived?
The Clausen function triplication formula is derived using complex analysis techniques and properties of the Clausen function. It involves manipulating the original function to express it in terms of simpler trigonometric functions.
What are some real-world applications of the Clausen function triplication formula?
The Clausen function triplication formula has various applications in fields such as physics, engineering, and computer science. It is used to solve problems in quantum mechanics, electromagnetism, and signal processing, among others. It is also used in the design of numerical algorithms and error correction codes.
16K
