A clock tower puzzle in a gravitational field
In summary: K smaller than it should be in the proper coordinate system. This is gravitational time dilation. It is the ephemeral observer's perspective that clocks have shrunk. In summary, General Relativity describes spacetime using a metric. The most common one is the Schwarzschild metric, which is valid at radii greater than the surface radius of a mass. If we assume constant angular position so that dθ=dø=0, then this metric relates local (proper) coordinate time and distance dτ and ds to something called Schwarzschild coordinates dr and dt, which may be roughly taken to be coordinates as viewed by a distant observer on ephemeral time. The mathematician can calculate
rlshuler
In General Relativity spacetime is described by a metric. The most common one is the Schwarzschild metric, valid at radii greater than the surface radius of a mass. If we assume constant angular position so that dθ=dø=0, then this metric relates local (proper) coordinate time and distance dτ and ds to something called Schwarzschild coordinates dr and dt, which may be roughly taken to be coordinates as viewed by a distant observer on ephemeral time. I'll call these ephemeral coordinates.
If we stack meter sticks up on two sides of a planet to make towers of equal height, then all observers will agree on the number of meter sticks simply by counting them. According to a proper observer (traveling along the towers), this is also the combined "proper" height of the towers. For simplicity, assume each one drills down to the center of the planet, or just ignore the planet. Trust me it doesn't make any difference and just messes up the calculation.
The mathematician can calculate the proper height of the towers by solving for and integrating ds. This is easy because the towers are static, i.e. not changing in time, and we can set dt=0, leaving only one term in the metric. The proper distance ∫ds=S will be greater than the ephemeral coordinate distance ∫dr=R by some factor K. This factor K is just the average of the coefficient in the metric over r, as that coefficient is a function of r. Nothing too mysterious.
The ephemeral observer will notice that light rays take longer than would seem necessary to cross the gravitational field. If the time interval is T, then R/T < c. That's OK because this is a non-local measurement of lightspeed, not a proper lightspeed. It is called a "coordinate" velocity. The ephemeral observer notices that T is greater than the expected time by the factor K that was found in the proper distance computation. So we have K(R/T)=(KR)/T=S/T=c and everything is OK. Using ephemeral coordinates, slow light travels the distance R and this produces time dilation. Using proper time and lengths, normal light travels the greater distance S and this produces time dilation. Everyone is in agreement about the objective facts. Who cares if their coordinates are different, right?
Now let's place mirrors at the ends of each meter stick and make a light clock out of it. I assume everyone knows what a light clock is. Photons bounce between mirrors and a timing signal is derived from that. We can even put these clocks in series so that each issues one "tick" after the previous one until they have all ticked. Then if we want to keep ticking, it goes back the other way. Obviously the total time for a complete group of ticks is T in ephemeral coordinates. The tick period for each individual clock is T/S, i.e. divide the total time by the number of clocks or meter sticks. I have conveniently made the number of clocks equal to the number of meter sticks by making them 1 meter long.
Since the ephemeral observer's coordinates measure the total distance as R < S, but the total number of meter sticks (or clocks) is S, then the ephemeral observer concludes the clocks have shrunk and are now only (on average, as the amount varies along the path) S/K in length (since KR=S). This is gravitational length contraction, seen only in the ephemeral reference frame, occasionally discussed but not too often. It is just the ephemeral view of the effects of what is a longer path in the proper view. Again, nothing too mysterious. Just games with coordinates. The objective observables are so far consistent. Everyone agrees on the total number of clocks or sticks.
OK, so the coordinate average length of a light clock is 1/K, since there were S of them at 1 meter each in the proper units. In ephemeral coordinates each is 1/K meters long. (K us usually a number very close to one)
Recall from earlier that the coordinate velocity of light in the ephemeral frame was slightly slow, again by a factor of K. It is exactly c/K.
Now the ephemeral observer computes the ticking rate of each 1 meter light clock. I will call these little ticks t to distinguish them from big ticks through the whole distance T. It is just the coordinate length divided by the coordinate velocity of light, tick = (1/K)÷(c/K) = 1/c.
OK, so everything in the BIG picture checks out in any coordinate system. The total interval T=S/c=KR/c as it should be. The total BIG tick T is longer by K in ephemeral coordinates reflecting time dilation.
Uh oh, something is wrong. The average little tick t=1/c is completely immune to time dilation. An individual clock is ticking always at its nominal rate!
You can re-do this analysis focusing on the little clocks, and get them to stretch. I'm sure I'll get half a dozen answers telling me to do that. I understand. I've done it already. BUT, if you do this, then you can't fit S of them into the big distance. Only R=S/K of them. BUT SINCE THE METER STICKS (LIGHT CLOCKS) are the REFERENCE STANDARD for proper distance, i.e. their count is the proper distance, then you have to conclude S=R in violation of the metric.
Can anyone REALLY explain this? I mean not just dodge the question. This is not an oh I just thought of this today question. I've been trying to figure it out for years, and have posted on other forums without anyone really giving an answer (so far).
Appreciate any help you can give. If no one can answer, what does that say?
Not a good sign, you've probably gotten a lot of good explanations and rejected them :(. But to be motivated to answer I'll have to hope that it's different time (I wish us luck!).
I'll focus on what I see as the problem, it's a rather long post.
I would say that coordinates only measure distance without correction when you have a particular sort of metric, a diagonal metric with unit coefficients. In fact, the whole purpose of a metric is to change the observer-dependent notion of coordinates into the (mostly) observer-independent notions of distance.
An aside: distance is invariant here only for the class of static observers, but that's just the class of observers we are interested in.
So the ephemeral observer's coordinates don't measure distance when you just subtract the difference, because you need to take into account the metric.
We conclude that the height of the tower, R, the proper height, an observer independent quantity, is the number of meter sticks it contains. But this proper height is not the difference in coordinates between the top and bottom of the tower, because the coordinates don't directly measure distance.
There is a conflict between the idea that "distance is measured by prototype meter bars" and the idea that "distance is measured by the change in coordinates". All you need to do is resolve the conflict in favor of the former (i.e that distance is measured by the number of prototype meter bars), and regard a change in generalized coordinates as something that can be converted into distance (using the metric), but it is not a distance until you do this conversion.
Ah... a much simpler formulation and possible explanation?
Suppose the coordinate distance in A's frame from A to B and back is R. A's radius is greater than B's. Then ∫ds=S=KR where K>1. So KR meter sticks can be laid from A to B and both parties will agree.
The coordinate velocity of light through each of A's coordinate meters is reduced by K in A's frame. This can be determined by dividing the coordinate distance R by the transit time in A's frame KR/c giving R/(KR/c)=c/K.
Time dilation for a proper 1 meter light clock is increased by K as viewed by A. This follows from time dilation alone without reference to length changes. But this is also the time dilation for A's coordinate meters, so A's coordinate meters must equal the proper meters.
Oh my ...
I think that the scale of local coordinates is arbitrary if one considers only one path segment, like a meter. The geodesic assumption removes this flexibility by requiring a scale choice that points the curvature tangent in the direction of motion derived from equivalence.
However, requiring that the whole equals the sum of the parts places also another constraint on the scale.
John Macken on another thread has pointed out the reason for the disagreement in my algebra. The coordinate velocity of light is proportional to K squared, not K.
This seems to be related to the Shapiro delay. It should directly verify curvature, since it is not explainable by time dilation alone. I spent a couple of hours with Cliff Will's book on GR verification, and searched the web, but I cannot find detailed information on the Shapiro experiments. A number was thrown out in one source of 200 microseconds change in delay, but that must be a typo. My own calculations show a range of 90 to 280 nanoseconds, depending on what assumptions are used, which differs by 3 orders of magnitude. Anyone have any information on this?
I find this puzzle intriguing and it highlights the complexities of General Relativity. The concept of time dilation and length contraction in a gravitational field is well-established and has been observed in various experiments. However, this puzzle raises some interesting questions about the behavior of light clocks in a gravitational field.
One possible explanation for the discrepancy in the ticking rate of the light clocks is that the concept of proper time, which is measured by a clock at rest in a given reference frame, may not be applicable in this scenario. In General Relativity, time is not absolute and can vary depending on the observer's frame of reference. So, while the individual light clocks may appear to be ticking at their nominal rate in the ephemeral reference frame, they may actually be experiencing time dilation in their proper reference frame.
Another explanation could be that the concept of simultaneity, which is also relative in General Relativity, plays a role in this puzzle. As the ephemeral observer measures the distance between the mirrors in the light clock to be shorter than the proper distance, they may also perceive the ticks to be occurring at a faster rate due to this difference in simultaneity.
It is also worth considering the effects of gravitational time dilation on the light clock itself. As the light clock is placed in a strong gravitational field, time would appear to move slower for the clock itself, which could contribute to the discrepancy in the ticking rate observed by the ephemeral observer.
Overall, this puzzle highlights the complexities of General Relativity and the limitations of our understanding of time and space in extreme gravitational fields. It also emphasizes the importance of considering all aspects of a problem and not just focusing on one specific frame of reference. Further research and experiments may shed more light on this puzzle and help us better understand the behavior of light clocks in a gravitational field.
Related to A clock tower puzzle in a gravitational field
What is a clock tower puzzle in a gravitational field?
A clock tower puzzle in a gravitational field is a thought experiment that explores the effects of gravity on the passage of time. It involves a clock tower at the top of a tall building, where time moves slower due to gravitational time dilation.
How does gravity affect time in this puzzle?
Gravity affects time in this puzzle through gravitational time dilation, a phenomenon predicted by Einstein's theory of relativity. The stronger the gravitational field, the slower time moves. In this puzzle, time moves slower at the top of the clock tower due to its proximity to the Earth's gravitational field.
What are the key components of this puzzle?
The key components of this puzzle are the clock tower, the gravitational field, and the observer. The clock tower represents a high point in the gravitational field, where time moves slower. The gravitational field is the force that causes time dilation. The observer is someone who can observe the effects of time dilation from different positions.
How does this puzzle relate to real-life scenarios?
This puzzle relates to real-life scenarios by demonstrating the concept of time dilation in a simplified way. In reality, time dilation is a crucial factor in GPS technology, as the satellites that make up the GPS system experience time at a slightly different rate due to their high orbits and the Earth's gravity. This must be taken into account for accurate GPS readings.
What are some potential applications for understanding this puzzle?
Understanding this puzzle can have various applications, such as in space exploration and satellite technology. It can also help us gain a better understanding of the effects of gravity on the passage of time and its implications for our understanding of the universe.
