A coin toss probability problem
  • Thread starter #neutrino
  • Tags
    Probability
In summary, you can use the usual notation of ##C_4^6## to calculate the number of ways to get three heads and three tails out of six other possible results.
#neutrino
51
If a fair coin is tossed 6 times what is the probability of obtaining 3 heads and 3 tails /
c(n,r)=n!
r!(n-r)!
the no of probable outcomes = 26
= 64
here's what i can't get around how to calculate the no. of times to get 3 heads and 3 tails out of all the other outcomes .
If you have to calculate something like this you could combine the probabilities. If you have to get the result X in the first experiment and the result Y in the second, the total probability is the product of the particular probabilities (only when the first experiment does not influence the second). also, the probability of getting the result the result X or the result Y in one experiment is the sum of the particular probabilities.(You should try to prove those theorems if you haven't herd of them before.)
In your problem, the probability of getting 3 heads and 3 tails is 1/26, but this result can be obtained in various combinations. The number of those ways to combine the results is the number of ways in which you can choose 3 experiments out of 6 to get one particular result. That's C63.
Notice that the number you are asking for is C63 and using your method you get the same result.
i still don't really get why we have to choose 3 experiments out of 6
Suppose you have 6 boxes numbered from 1 to 6. Each time you toss the coin you write the result on a paper and put it in the connected box (the first result in box 1, the second in box 2, etc.). You aim to have three papers on which is written tails and three on which is written heads.
Now if you get three papers of each result, you might choose for example tails. Put all the papers with tails in the boxes. This way you get a way of combining your 3-3 result, because the empty boxes will get the rest of the papers (the ones with heads). So it is enough to put one set of papers to get a solution. that's why you can choose just 3 boxes(experiments) out of 6.
You can think the same for results like 2 tails- 4 heads. This way you can observe that the number you get from choosing 2 experiments out of 6 or 4 out of 6 gives the same result. So you will practically prove that C62 = C64.
Likes #neutrino
yup thnx got it
Likes anachin6000
The usual notation (at least in North America) is ##C_4^6##, not ##C_6^4##, although ##{}_6C_4## or ##{6 \choose 4}## are preferred.
Well, I'm from Europe. But is nice to learn worldwide notations:)
Related to A coin toss probability problem
1. What is a coin toss probability problem?
A coin toss probability problem is a mathematical problem that involves determining the likelihood of a specific outcome when a coin is flipped. This problem typically involves calculating the probability of getting a certain number of heads or tails after a certain number of tosses.
2. How do you calculate the probability of getting a specific outcome in a coin toss?
To calculate the probability of getting a specific outcome in a coin toss, you need to divide the number of ways that outcome can occur by the total number of possible outcomes. For example, if you want to know the probability of getting exactly 3 heads in 5 coin tosses, you would divide the number of ways to get 3 heads (10) by the total number of possible outcomes (32), resulting in a probability of 10/32 or 0.3125.
3. Are coin tosses truly random?
Coin tosses are considered to be random because there is no way to predict the outcome with 100% accuracy. However, there are some factors that may influence the outcome, such as the force and angle of the toss, the condition of the coin, and the surface it lands on.
4. How does the number of coin tosses affect the probability of a specific outcome?
The more coin tosses you have, the closer the actual results will be to the predicted probability. For example, if you toss a coin 100 times, you are more likely to get close to 50 heads and 50 tails than if you only toss it 10 times.
5. Can coin toss probability problems be applied to real-life situations?
Yes, coin toss probability problems can be applied to real-life situations. For example, they can be used in gambling and games of chance, as well as in statistical analysis and decision-making processes.
