A compound with a molecular weight of 110.1 g
In summary, the conversation is about finding the molecular formula of a compound with a molecular weight of 110.1 g, containing only C, H, and O. The combustion of a 5.19 g sample of the compound resulted in the formation of 12.4 g of carbon dioxide and 2.55 g of water. Through calculations and conversions, it was determined that the compound has a molecular formula of C6H6O2. The conversation ends with a thank you and holiday wishes.
priscilla89
A compound with a molecular weight of 110.1 g that contained only C, H, and O was analyzed by combustion. the combustion of a 5.19 g sample of the compound resulted in the formation of 12.4 g of carbon dioxide and 2.55 g of water. What is the molecular formulas of this compound?
2. The attempt at a solution
CO2
12.44
------ = .2818
44
But I'm confused on how to do this for H20
Is it this below?
2.55
= .1416
Thats correct for the moles of water, and for the hydrocarbon, 5.19g/110.1g/m = .0471 moles.
So now you can get the molar ratios for the reaction . And from there the formula for the hydrocarbon.
Moles of water is not moles of hydrogen. They are related, but not identical.
Were not looking for moles of hydrogen, we want to know how many hydrogens on the
reactant. So .1416 moles water/.0471 moles hydrocarbon = 3/1
So with three waters in the product we have 6 hydrogens on the hydrocarbon.
Sorry, my lack of clarity. I was not referring to the moles of molecular hydrogen, just the fact moles of water have to be converted to moles of atomic hydrogen. That means moles of water times two, that's what you did. We were talking the same all the time, obviously neither of us was entirely clear.
Right, now I understand it. You would've to do the same for CO2::
CO2
.2818 / .0471 = 6
C6 H6 O2
Thanks for the help. I really do appreciate this
- Happy Holidays Everybody
FAQ: A compound with a molecular weight of 110.1 g
What is the molecular weight of a compound with a molecular weight of 110.1 g?
The molecular weight of a compound is the sum of the atomic weights of all the atoms in its chemical formula. Therefore, a compound with a molecular weight of 110.1 g would have a total mass of 110.1 grams.
How is the molecular weight of a compound determined?
The molecular weight of a compound can be determined by adding up the atomic weights of each element in its chemical formula. This can be found on the periodic table of elements.
Is the molecular weight of a compound a fixed value?
Yes, the molecular weight of a compound is a fixed value as it is determined by the atomic weights of its constituent elements, which are constant.
How does the molecular weight of a compound affect its properties?
The molecular weight of a compound can affect its physical and chemical properties. Generally, compounds with higher molecular weights tend to have higher melting and boiling points, as well as lower rates of evaporation.
Can two compounds have the same molecular weight?
Yes, it is possible for two different compounds to have the same molecular weight. This is known as isomers, where two compounds have the same molecular formula but different structural arrangements of atoms.
11K
9K
10K
