A conceptual question about the force of light waves when reflected
In summary, an EM wave with an intensity of 200 W/m^2 is normal to a black 0.2m x 0.3m card that absorbs 100% of the wave. The force exerted on the card by the radiation is 4*10^-8 N. If the card reflects 100% of the light, the force exerted by the same wave is double the original force. This is because in order to reflect the wave, the card needs to not only bring its velocity to zero but also send it back in the opposite direction at the incoming speed, requiring an impulse twice as large to change the momentum.
RubberBandit
An EM wave with intensity=200 W/m^2 is normal to a black .2m x .3m card that absorbs 100% of the wave. (a) Find the force exerted on the card by the radiation. (b) Find the force exerted by the same wave if the card reflects 100% of the light.
Pr=I/c Pressure=F/A
Part (a) I solved. (I/c)(0.2*0.3)=F=4*10^-8 N
Part (b) I know is double the force.
My question is conceptual. Why is the force doubled when the EM wave is reflected?
Thank you for any and all replies.
Think about it in terms of momentum. Force is what is required to change momentum; a net change in momentum due to a force is usually called an impulse. In the case of absorption, you only need the card to provide an impulse equal in magnitude to the momentum, which is opposite in direction to the light wave. This will exactly stop the wave. On the other hand, if you want to reflect the wave, you need to not only bring its velocity to zero but then to send it back in the opposite direction at the incoming speed. In other words you need to impart an impulse twice as large because the magnitude of the change in momentum is twice as large.
That makes perfect sense. Thank you Steely Dan.
PS Love your handle. Get along Kid Charlemagne.
Related to A conceptual question about the force of light waves when reflected
1. What is the force of light waves when reflected?
The force of light waves when reflected is the pressure or energy exerted by the light waves on a surface when they bounce off of it. This force is known as radiation pressure, and it is a result of the momentum of the light particles.
2. How does the force of light waves when reflected affect objects?
The force of light waves when reflected can have a variety of effects on objects depending on their material and shape. For example, it can cause objects to move, vibrate, or even break if the force is strong enough.
3. What factors influence the force of light waves when reflected?
The force of light waves when reflected is influenced by several factors, including the intensity and wavelength of the light, the angle of incidence and reflection, and the properties of the reflecting surface such as its material and texture.
4. Can the force of light waves when reflected be measured?
Yes, the force of light waves when reflected can be measured using instruments such as a radiometer or a laser force sensor. These devices can detect the pressure or energy exerted by the reflected light and provide a quantitative measurement.
5. How does the force of light waves when reflected contribute to everyday life?
The force of light waves when reflected plays a crucial role in many everyday activities and technologies. For example, it allows us to see objects through reflection, powers solar sails and solar panels, and is used in various industrial processes such as laser cutting and welding.
  • Electromagnetism
