A couple of questions about the spin of a nucleus?
In summary, the Pauli exclusion principle determines the arrangement of protons and neutrons in the shells of an atomic nucleus. The s, p, and d shells correspond to different orbital quantum numbers, and the s shell has 2 possible states while the p shell has 6. The shells also have a spin-orbit interaction, resulting in different possible values for the quantum number j. The j=3/2 level is filled before the j=1/2 level due to its slightly lower energy. The total spin of the carbon-12 nucleus is zero due to the alternating spin arrangement of its protons and neutrons.
jeebs
325
Hi,
I have a couple of questions about the spin of an atomic nucleus.
Say I had a carbon-12 nucleus, which is 6 protons and 6 neutrons. The Pauli exclusion principle tells us that these should be arranged in shells determined by their orbital angular momenta and spins.
So, the shell order goes 1s, 1p, 1d, 2s, 1f, 2p... and the s shell has orbital quantum number l=0, the p shell l=1, and so on, like electrons in atoms, right?
In the s-shell, there are 2 possible states, one for spin up, one for spin down.
In the p-shell, there are 2(2l + 1) states = 2(2 + 1) = 2(3) = 6 available states.
Also, the shells have a spin-orbit interaction, ie. j = l + s.
This gives us the possible values of the quantum number j of |l+s| to |l-s|
ie. j = 1+(1/2) to 1-(1/2)
= 3/2 and 1/2
Now in the j=3/2 level, there are 4 mj states available: -3/2, -1/2, +1/2 and +3/2
and in the j=1/2 level, there are 2 mj states: -1/2 and +1/2.
So, in this nucleus we have 6 protons. They fill up the shell levels from the lowest states, so the 1s shell gets filled, and from what I can gather, the 1p3/2 level gets filled up.
My first question is, why does this level get filled up first and not the j=1/2 level? Am I right in thinking that the 3/2 level corresponds to the orbital and spin angular momentum vectors adding in the same direction, anf the 1/2 level corresponds to the spin and orbital angular momentum vectors opposing each other?
If so, shouldn't the 1/2 level be at a lower energy and therefore filled up first, seeing as if there is less total angular momentum the nucleus should be in a less excited state?
My other question is, what is the total spin of this carbon-12 nucleus?
Do the spins of each successive nucleon added to the nucleus go in alternating up, down, up, down order, meaning that for an even number of protons they would contribute no spin angular moment to the overall nuclear spin (with the same being true for neutrons)?
Thanks.
The first question is a bit complicated, but the basic idea is that the j=3/2 level is actually slightly lower in energy than the j=1/2 level. This is because the spin-orbit interaction is stronger for higher angular momentum states, so the j=3/2 level has a slightly lower energy than the j=1/2 level. So, the protons will fill up the j=3/2 level before the j=1/2 level. For the second question, it is true that the spins of each successive nucleon added to the nucleus goes in alternating up, down, up, down order, meaning that for an even number of protons they would contribute no spin angular moment to the overall nuclear spin (with the same being true for neutrons). Therefore, the total spin of the carbon-12 nucleus is zero.
FAQ: A couple of questions about the spin of a nucleus?
What is the spin of a nucleus?
The spin of a nucleus refers to the intrinsic angular momentum of the nucleus, which is a fundamental property of all atomic nuclei. It is measured in units of Planck's constant divided by 2π.
How is the spin of a nucleus determined?
The spin of a nucleus is determined by studying the behavior of the particles within the nucleus, such as protons and neutrons. By measuring the energy levels and angular momentum of these particles, scientists can determine the overall spin of the nucleus.
Why is the spin of a nucleus important?
The spin of a nucleus is important because it affects the stability and properties of an atom. It also plays a role in nuclear reactions and the behavior of particles within the nucleus.
Can the spin of a nucleus change?
Yes, the spin of a nucleus can change through nuclear reactions or interactions with other particles. However, the total spin of a closed system is always conserved.
How is the spin of a nucleus related to nuclear magnetic resonance (NMR) imaging?
Nuclear magnetic resonance imaging uses the spin of atomic nuclei to create images of the body's internal structures. By manipulating the spin of these nuclei in a magnetic field, scientists can produce detailed images of tissues and organs.
