- #36
JesseM
- 16
Sure, he uses the two postulates to derive the Lorentz transformation (or specific consequences of the Lorentz transformation like time dilation), and that's how most textbooks do it too. But that doesn't mean this is the only valid way to derive the Lorentz transformation, you could derive them starting from some different assumptions which don't talk about the one-way speed of light.ghwellsjr said:JesseM, I don't know how you manage to whip up so many comments in such a short time. It takes me days to digest what you are saying and formulate my responses but I'm finally ready to take a stab at your comments but I want to do it in a general sense rather than specifically quote each of your statements.
In both Einstein's 1905 paper and his 1920 book which we have been quoting from in this thread, Einstein is starting with the two postulates or principles as he sometimes calls them. The first is the Principle of Relativity (which is not his theory of relativity) and the second is the Principle (also called the Law) of Constancy of the One-way Speed of Light. See the beginning of article 2 of his 1905 paper and the end of Chapter VII of his 1920 book where he elucidates these two Principles. Although these two Principles are "apparently irreconcilable" (as he says in the introduction of his paper) or suffer "apparent incompatibility" (as he says in the title of chapter VII of his book), his Theory of Special Relativity affirms both of them by redefining the concepts of space and time from their commonly held definitions prior to the introduction of his theory.
No, it doesn't. I understand he was not in that case using slow transport to define simultaneity, but just because he was using one particular derivation doesn't mean he would declare any alternate derivation to be invalid! I'm sure he would acknowledge there are multiple distinct set of starting axioms you can use to derive any specific result like time dilation, just like there are multiple valid derivations of a mathematical result such as the Pythagorean theorem. My point all along was that it's meaningful to talk about measuring the one-way speed of light relative to a particular set of starting assumptions, like the assumption that we synchronize clocks using a slow transport method.ghwellsjr said:So, when you ask me if his definition of simultaneity can be changed from one based on the one-way speed of light to the slow transport of clocks, it misses the whole point of what he is doing.
Sure, I agree that as a historical matter it's unlikely SR would have been first thought up based on axioms which have nothing to do with light. But that's just history, I don't think it has anything to do with the abstract non-historical question of whether it's meaningful to talk about measuring the one-way speed of light.ghwellsjr said:If Einstein had postulated that slow moving clocks do not change their tick rates, then he could have used that as the basis for his argument. But the problem with that is that no one would have suggested that slow moving (or maybe even fast moving) clocks should change their tick rates and thus be apparently irreconcilable or have any apparent incompatibility with the Principle of Relativity. If there's no problem, there's no need for a theory to solve the problem.
