MHB A curvature problem (differentiation)
In the discussion on curvature in the Euclidean plane, the relationship between the curvature $$\kappa$$ of a differentiable function $$y=f(x)$$ and the angle $$\phi$$ formed by the tangent line at a point is established. The curvature is defined as the rate of change of $$\phi$$ with respect to arc length $$s$$, leading to the formula $$\kappa = \frac{d\phi}{ds}$$. The participants derive that $$\kappa$$ can be expressed as $$\kappa = \frac{ \left[ 1+ \left( \frac{dy}{dx} \right)^2 \right]^{3/2} }{ \frac{d^2y}{dx^2} }$$. The discussion also clarifies the differentiation process, linking the second derivative of the function to the angle's derivative and the arc length. Ultimately, the derived formula for curvature is confirmed as $$\kappa= \frac{f''(x)}{\left [1+f'(x)^2 \right]^{3/2}}$$.
DreamWeaver
In the Euclidean plane, assume a differentiable function $$y=f(x)$$ exists. At any given point, say $$(x_0,y_0)$$, the line tangential to $$y=f(x)$$ at this point intersects the x-axis at an angle $$\phi$$.
The curvature of this curve, $$\kappa$$, is the rate of change of $$\phi$$ with respect to arc length, $$s$$:
$$\kappa = \frac{d\phi}{ds} $$Problem:Prove that
$$\kappa = \frac{ \left[ 1+ \left( \frac{dy}{dx} \right)^2 \right]^{3/2} }{ \frac{d^2y}{dx^2} }$$Or equivalently
$$\kappa = \frac{\left[ 1+\left( f'(x) \right)^2 \right]^{3/2}}{f''(x)}$$
Mathematics news on Phys.org
Here's an optional, visual aid, for a generic curve. Just in case... (Bandit)
Isn't
$$\kappa = \frac{f''(x)}{ \left [ 1+ (f'(x))^2 \right ]^{3/2}}$$?
The solution follows.
First, $$\frac{d \varphi}{ds}= \frac{\frac{ d \varphi}{dx}}{ \frac{ds}{dx}}$$.
If the tangent line to f(x) at $$x=x_0$$ intersects the x-axis at an angle $$\varphi$$, then $$f'(x_0) = \tan \varphi$$. Differentiating both sides with respect to $$x_0$$ and assuming $$\varphi$$ is a function of $$x_0$$ gives $$f''(x_0)=\varphi' \sec^2 \varphi $$. Solving and remembering that $$1+\tan^2 (x)=\sec^2 (x)$$, we have
$$\frac{f''(x_0)}{1+f'(x_0)^2}= \varphi'=\frac{d \varphi}{dx}$$.
Now, remembering the definition of arc length,
[math]\frac{ds}{dx}= \sqrt{1+f'(x)^2}[/math],
substituting into the first equation, and dropping subscripts gives our result,
$$\kappa= \frac{d \varphi}{ds}= \frac{f''(x)}{\left [1+f'(x)^2 \right]^{3/2}}$$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
