A curve that intersects itself at some point w/o trig functions
In summary: Now what about a function that relates each member of the input set to more than one member of the output set? It is called a multivalued function. Now what about a function that relates each member of the output set to more than one member of the input set? It is called... an inverse relation. I think that answers the question of the thread starter. I hope you don't have any more questions.In summary, a function must pass the vertical line test, meaning each x value must produce only one y value. A circle is not a function because it produces two y values for some x values. However, a curve with a loop can also fail the vertical line test and not be a function.
Lebombo
144
In order for an equation to be a function, it has to pass the vertical line test.
A circle is not a function because it does not pass the vertical line test.
A curve containing a loop does not pass the vertical line test and to me that means it is not a function.
However, if I am given two parametric equations, x(t) and y(t) that both seem to be functions (passing the vertical line test), and am provided a picture of the graph of the parametric equations, if the curve of the parametric equations contains a loop, I would assume right away that the combined equation, y(x), can not be a function because the graph has a loop.
So if I have x(t) = t^{5} + 4t^{3} and y(t) = t^{2}
And because x(t) is not solvable, I can't sub the t(x) into y(t), but I can sub t(y) into x(t):
[itex]x(y) = ((+/-)y^{5/2}- 4(+/-)y^{3/2}[/itex]
[itex]x= y^{5/2}- 4y^{3/2}[/itex] or [itex]x= -y^{5/2}+ 4y^{3/2}[/itex]
My question is here:
Is there anything specific about this function or a function of similar form that enables me to see that A) it is not a function B) It creates a loop when graphed (implying there is at least some point at which the curve intersects itself)?
Mathematics news on Phys.org
The vertical line test you mentioned simply means finding out whether there is a single x that gives two different ys or not.You can figure that out by some calculation too.
Consider the equation of a circle: [itex] x^2+y^2=R^2 [/itex]. I can write [itex] y=\pm \sqrt{R^2-x^2} [/itex]. It is obvious that there exits some x that give two different ys. In fact all x gives two different ys except x=R. So from the equation of a circle,you can get a function!
Shyan,
So when given the parametric equations:
x(t) = [itex]t^{5} + 4t^{3}[/itex] and [itex]t^{2}[/itex]
At what point can I determine the equation will or will not pass the vertical line test (be or not be a function)?
Question 1) Can I tell by looking at the set of parametric equations given, or can I only tell by looking at the combined x(y) function?
Question 2) If x(t) can not be solved in terms of t(x), then how can x(y) be solved in terms of y(x)?
That is, are you saying that it is possible to isolate y to one side in this(these) equation(s)?
I believe I just learned that a function of this particular form can not be solved for the independent variable, so it doesn't seem to follow the example with the circle you provided, due to being a 5th degree polynomial, unless I'm neglecting some other facts that I'm not yet aware of.
This you may consider pedantic but you wait till you see the guys who come next.
At least in my time a function is not what you think - what you think used to be called a "single-valued function". A function in my day was just a rule, give x calculate something, not necessarily only one thing, called f(x), by the rule. And yes, the most usual, useful ones tended to be single valued, and you tended to think they are all like that. But even when you defined them to be like that, their inverses often aren't.
Functions have tended to be replaced by "mappings" which I think is almost the same thing (:rolleyes: we'll soon hear :biggrin:) and which may have been more evocative if I hadn't got used to functions, that maybe emphasizes more calculation.
epenguin,
I think I kind of understand what you mean. I don't consider an equation a function if one x produces more than one y's.
Suppose I have a curve that creates a loop. The equation that describes that curve is not considered a function because of the rule that one x must produce one y.
However, can a curve of this type be described by some sort of equation? That is, an equation which does not include trig functions?
Did you read post #2 in this thread?
But I thought [itex] y=\pm \sqrt{R^2-x^2} [/itex] is not a function exactly because one x value gives two different y values. I thought it can't be a function unless you write it expressly as two different equations, at which point there are now two separate functions.
I think Lebombo has problem with my post because of the following line:
It was just a miss-typing.In fact I meant:
So from the equation of a circle,you can't get a function!
Going with the definitions,I can say there can exist a relation between the members of two sets(which can be the same). If the relation gets one member of the input set and gives one member of the output set,it is called a binary relation. If this binary relation, relates each member of the input set to only one member of the output set, it is called a function. If this function relates each member of the output set to only one member of the input set,it is called a one to one function. If for every member of the output set,there exists a member of the input set which is related to it by our function,our function is called an onto or Surjective function.
Related to A curve that intersects itself at some point w/o trig functions
1. What is a curve that intersects itself without using trigonometric functions?
A curve that intersects itself at some point without using trigonometric functions is known as a self-intersecting curve. These curves can be represented by equations that involve polynomial, exponential, or logarithmic functions, among others.
2. How do you graph a self-intersecting curve?
To graph a self-intersecting curve, you can use a graphing calculator or software such as Desmos. Simply input the equation of the curve and the software will generate a graph for you to visualize the curve.
3. Can a self-intersecting curve have more than one point of intersection with itself?
Yes, a self-intersecting curve can have multiple points of intersection with itself. The number of intersections depends on the complexity of the equation and the range of the independent variable.
4. What is the significance of self-intersecting curves in mathematics?
Self-intersecting curves have been studied extensively in mathematics and have many applications in fields such as topology, geometry, and physics. They can also be used to create interesting and complex shapes in art and design.
5. Are there any real-life examples of self-intersecting curves?
Yes, there are many real-life examples of self-intersecting curves. Some common examples include knots, spirals, and certain types of fractals. These curves can also be observed in nature, such as in the shape of a DNA molecule or the structure of a fern leaf.
  • General Math
  • General Math
  • General Math
