Jaccobtw
- 163
- 32
- Homework Statement
- A wire is bent to contain a semi-circular curve of radius 0.25m. It is rotated at 120rev/min as shown into a uniform magnetic field below the wire of 1.30T. What is the maximum emf induced between the left and right sides of the wire in V?
- Relevant Equations
- $$\Phi =\int_{}^{}B \cdot dA$$
$$\varepsilon = -\frac{d\Phi}{dt}$$
If I'm correct then the maximum change in magnetic flux occurs when the semi circle crosses the point at which it's plane is parallel with the magnetic field and minimal when it crosses the point at which the magnetic flux is maximum ( perpendicular with the field). I'm having trouble writing a function because I'm assuming the magnetic field is located only below the wire and NOT in the semicircle in its up most position. Any ideas? Thank you.
