A cylinder on an inclined plane with rope
A cylinder on an inclined plane is analyzed to determine its speed and angular velocity when subjected to different angles and friction. The initial speed at a 30-degree angle is given as 1 m/s, and the task is to find the speed at a 60-degree angle, considering a coefficient of friction of 0.2. Discussions emphasize the need to account for both translational and rotational dynamics, including tension and friction in the equations. The confusion arises around the effects of rolling versus slipping and the correct application of the moment of inertia for a hollow cylinder. The conversation highlights the importance of correctly applying physics principles to solve for the cylinder's behavior on the incline.
darxsys
A cylinder, with a rope wrapped around it, is placed on top of an inclined plane.If the speed of the cylinder in the bottom of the plane, when the angle of the plane is 30 degrees, is 1m/s, find what speed will the cylinder have when it is placed on a plane with an angle of 60 degrees. The length of the plane is 3m, radius of the cilinder is 0,5m, and the coefficient of friction is 0.2. Find the time needed for the cylinder to get to the bottom of the plane in case of a 60 degrees angle and find angular velocity of the cylinder when it is exactly on half of the height of the plane.
I hope I translated this correctly and that you'll be able to get it. Any help appreciated.
picture: http://img822.imageshack.us/img822/3240/screenshot3wb.png
I don't know how to put the equations right. Both friction and tension are needed in translational part. I thought of something like this:
mgsin\beta - T - Fr = ma
for the rotational part:
M = Mt - Mfr
I don't know what to do next.
I tried something using conservation of energy to find speed at the bottom of the plane, but I don't think I got it right cause I never used the coefficient of friction in my calculations nor tension of the rope.
welcome to pf!
hi darxsys! welcome to pf! :smile:
darxsys said:
… I tried something using conservation of energy to find speed at the bottom of the plane, but I don't think I got it right cause I never used the coefficient of friction in my calculations nor tension of the rope.
he he :biggrin:
from your picture, the rope is fixed to the top of the plane, and goes over the top of the cylinder …
that means that the cylinder "rolls along the rope", but slips down the plane :wink:
thanx :DWell, if it slips down the plane, then my first equation becomes mgsin\beta - \mu mgcos\beta- T?
But now, what to do with the angular momentum? It should stay the same as I wrote it?
I mean, I don't have an exact idea of what should I calculate in order to have enough data to find velocity at the bottom of the plane? are both rolling and slipping important for that? I can get the tension from the two equations above now that i know friction, so now i can just ignore rolling and only consider slipping?
hi darxsys! :smile:
as with all rotation problems, you need a linear equation, an angular equation, and an equation relating v and ω to connect them :wink:
well that's the problem. i know that v = r\omega and i wrote the equations for both rolling and slipping.ma = mgsin\beta - \mumgcos\beta - T
I\alpha=rT - rmg\mucos\beta
from which I got T = \frac{mg}{2}sin\beta
and got the acceleration 0,753 m/s^2. but the problem is that now i get that velocity in beta case is 2,12m/s when it reaches bottom of the plane and not 1 m/s
you've used I = mr2
it isn't :redface:
Why not? its a hollow cylinder. i forgot to mention that. sorry. but that doesn't really change a lot does it?
http://en.wikipedia.org/wiki/List_of_moments_of_inertia
first one?edit: i assume that the friction in beta case is not the same as in alfa case, but then again, i don't even need the beta case to calculate everything. I am totally confused :D
  • · Replies 26 ·
  • · Replies 36 ·
