A cylinder with cross-section area A floats with its long axis vertical
In summary: Welcome! Could you identify the variables shown in the posted equation?Could you post any work that you have done about trying to find the solution?
BlackPhysics
31
Summary: A 5.0- cm -diameter cylinder floats in water. How much work must be done to push the cylinder 11 cm deeper into the water?
F =Aρgx
F =Aρgx
x being the distance being pushed down.
Welcome to PF.
Is this a homework problem?
If it sinks a further 11 cm, how much additional displacement will there be?
Force is not work done.
Baluncore said:
Welcome to PF.
Im confused with that as well. This is all the information I am given
This is homework
Work done is force times distance moved.
In this case, you will apply a force to displace a volume of water. That force will be zero at the start, then will increase to a maximum when the rod is 11 cm deeper.
What volume of water will then be displaced ?
What will the final force be ?
Welcome!
Could you post any work on the solution?
It depends how broad the surface of the water is. If the cylinder fits snugly in a tank barely any wider then very little work is needed.
So assume an infinite expanse of water. That way, the level at the top of the water does not change.
Given that, what volume of water is displaced, and how much is its mass centre raised?
Lnewqban said:
Welcome!
A cylinder with cross-section area AA floats with its long axis vertical in a liquid of density ρρ.
F=Aρgx
A 5.0-cmcm-diameter cylinder floats in water. How much work must be done to push the cylinder 11 cmcm deeper into the water?this is all that is given
F=Aρgx
If you make the assumption of a very large body ( as @haruspex has pointed out ) of water (look up waters density), you have the information necessary to solve the problem if you know the definition of Work?
F=Aρgx
Hi @BlackPhysics. Welcome to PF. The rules here require you to show evidence of your own effort before we offer help. It's worth taking a quick look at the guidelines:
https://www.physicsforums.com/threads/homework-help-guidelines-for-students-and-helpers.686781/
- especially Rule 4!
The general approach here is that we guide you through a problem so you can work it out for yourself.
You need to check what has been said in previous posts. For example @Lnewqban (in Post #5) asked you to give the meaning of each variable in your equation. But you haven't answered yet.
Likes Lnewqban
F=Aρgx
All that information I have read it in your first post.
Again, help us to help you:
what i have done is take the area of the cross sectional area which is
pi * 2cm^2 * 1000 kg.m^3 * 9.8 * 11cm
That appears to be the change in the Buoyant Force of water you have calculated, not the cross-sectional area of the cylinder?
EDIT:
Well...its not even really that. Where is the ##2 \, \rm{cm}^2## coming from?
EDIT:
that was me using the a*p*g*x the A is the cross sectional area is what i am thinking
i guess it's supposed to be 2.5cm^2
the area of a circle is pi * r^2
Thats not the area in terms of the diameter. And where is that decimal point coming from?
Sure, if the buoyant force were constant that would be the Work?
Likes erobz
Correct. So, what is its cross sectional area?
Lnewqban said:
Welcome!
f = force
a = area
p = rho/density
g = gravity
x= displacement
78.54cm^2
  • Skeptical
Likes erobz
BlackPhysics said:
78.54cm^2
What formula have you used to get that?
BlackPhysics said:
78.54cm^2
As of right now i am getting 8.46 J and it is wrong
f= (78.54cm) * (1000 kg/m^3) * (9.8 m/s^2) * (11cm)
(pi * r^2) = area of a circle
You haven't used it correctly. What does ##r## stand for in that formula?
radius. the diameter is 5.0 cm so half of that is the radius.
Likes erobz
Ok, fix that then we will move on.
A=πr^2
78.54 = π * 2.5^2
BlackPhysics said:
f = force
a = area
p = rho/density
g = gravity
x= displacement
ok, but what force exactly?
f is a force, not work, as was pointed out in post #4. Its units may be Newtons, not Joules.
The 78.54 is presumably supposed to be the horizontal area, but I don’t know how you got that from ##\pi 2.5^2##, and the units should be ##cm^2##.
When you have corrected that equation, what force does f represent?
BlackPhysics said:
A=πr^2
78.54 = π * 2.5^2
No. It doesn't.
BlackPhysics said:
A=πr^2
78.54 = π * 2.5^2
##\pi## is not equal to 10.
  • Haha
Likes erobz
  • #31
im being dumb sorry its 19.63
  • #32
19.63= π * 2.5^2
  • #33
BlackPhysics said:
19.63= π * 2.5^2
Ok, now that you have that. Is it a good idea to multiply units of ## \rm{cm}^2## and ##\rm{m}## etc...as you have done in post #22? Firstly, its best to work with all variables until the calculation step, but if you insist, I think you should convert all figures to standard units.
  • #34
(0.01963m) * 1000 kg. m^3 * 9.8 m/s^2 * (0.11m)
Area Density G X
  • #35
Area Density G X
Ok, but the units are ##\rm{m}^2## on area. you have ##\rm{m}##, otherwise the values are ok.
Now we can move on to the definition of Work. What is it?
