A different related rates problem - no time mentioned
In summary: I suppose I just thought that it made sense that it was the case. For the cone, there can be only one place where the height is equal to 2, and that will have a specific radius. If we move up, the radius gets smaller and if we move down, the radius gets bigger. So the height would stay the same, just the radius changes.
opus
131
Evening all. I have a related rates problem that I haven't come across which doesn't seem to involve time which is usually the independent variable that we take the derivative with respect to. It has thrown me for a loop.
Find the change in the volume of a right cylinder cone with a height of 2 if the radius r changes from 0.5 to 0.55.
##V = \frac{1}{3}πr^2h##
The set up is where I'm not doing too well. Normally, if the related rates problem had time as an independent variable, I would do as such:
1) Find an equation that relates the variables to each other.
2) Find an equation that shows the rate of change with respect to the independent variable (time usually).
3) Take the derivative of both sides of the equation relating the variables to each other with respect to the independent variable. I would now have an equation that relates the rates of change of everything.
4) Plug in the given rate of change, and solve for the other rate of change.
In this case, as far as I've gotten is to say that I want the change in volume when the change in radius is 0.05 which is given in the question. The change in volume seems to need to be written as ##\frac{dV}{dr}##, as we want the change in volume with respect to the radius. But as for writing the change in radius, it doesn't make sense to write ##\frac{dr}{dr}##.
Another thing I did is to get the equation in terms of just radius so I'm working with less variables:
##V = \frac{1}{3}πr^2\left(\frac{2r}{r}\right)## but I don't think this is being much help.
As you can see, I am a mess with this one, so any pointers would be greatly appreciated!
The way it is phrased your problem does not involve any derivatives at all. It is just asking you for the difference between two volumes.
Likes opus
You seem to be trying to shoe-horn this problem into being rate related when it is not. Nowhere in the question you have stated is a rate asked for. It seems to be a simple problem of finding two volumes and taking the difference.
EDIT: I see orodruin beat me to it :smile:
Likes opus
Ok thanks for clearing that up guys. Looks like a curve ball where we were doing a lot of related rates and I just expected this one to be one as well. Oldest trick in the book!
So the book says that ##ΔV = \frac{π}{30}## and I can't quite come up with that.
What I did was take the volume when r = 0.5 and when r = 0.55 and subtract the two to get a total change in volume but somewhere I'm going wrong.
Since the radius is at different lengths, then that would mean that the height is different at these different radii. So to account for this, I said that ##\frac{r}{h} = \frac{r}{2}## and it follows that ##r = \frac{2r}{2}##. The reason I did this is so that it takes into account the fact that the height will be different with different radii, and since we have a right triangle in regard to the height and radius, then similar triangles apply.
So I have written:
##ΔV = \frac{1}{3}π\left(0.55\right)^2\left(\frac{2(0.55)}{2}\right) - \frac{1}{3}π\left(0.5\right)^2\left(\frac{2(0.5)}{2}\right)## which doesn't give a clean number like ##\frac{π}{30}##
This is probably a really dumb mistake. I'm on my 47th calculus problem today preparing for my exam and my brain is a little shot so I apologize for any stupidity that comes across my posts.
Why? Nowhere in the problem is it stated that the height changes.
Based on the given answer the book is approximating the change by the derivative wrt r multiplied by the change in r. To me that is a completely unnecessary approximation the way the problem is phrased.
Likes opus
The idea is that ##{\Delta V \over \Delta r} \approx {dV \over dr}##. So if you know ##dV \over dr##, you can find ##\Delta V## approximately given ##\Delta r##. Definitely the height is remaining constant. The only change is the radius. See if you can work it out.
Likes opus
Are you talking about using linear approximations where we could use the tangent line of a function at a point to estimate what value the function will have with a corresponding change in x? --> ##y=f(a)+f'(a)(x-a)##
I thought ΔV was the same as ##dV##?
I tried something a little different as it was something I remembered from the book where you can approximate what a function is going to be after a small change in the input values:
##f(a+h) ≈ f(a)+f'(a)h##
##≈\left(\frac{2π}{3}(0.5)^2\right)+\left(\frac{4π}{3}(0.5)\right)0.05## but this was way off which in hindsight makes sense because it's asking for the change in the volume, not what it's new value is. So I took this value, 1.57, and subtracted it from the volume where r=5.
This gave me 1.04 which is off by a decimal place to what would equate to ##\frac{π}{30}##. Must be on the right track but there are no mistakes in the calculator so it must be somewhere else.
No, they're not the same. ##\Delta V## is the exact change in volume. ##dV## is the differential change in volume, and is equal to ##\frac 4 3 \pi r~dr##.
Since ##f(a + h) \approx f(a) + f'(a)h##, it follows that ##f(a + h) - f(a) \approx f'(a)h##. Also, ##\Delta f = f(a + h) - f(a)##, by definition. From the first equation, you can approximate ##\Delta f## by ##f'(a) h##.
When I put the numbers in, I get the approximate change in volume agreeing with the exact change in volume in the first two decimal places. It could be that your value of 1.57 was rounded off but shouldn't have been.
Likes opus
So I have written:
I think the book wants you to think about fast and useful approximations. If you use the "differential (tangent-line)" approximation, you get
$$\Delta V_{approx} = V'(r)|_{r=0.5} \:\Delta r = (2 \pi/3) \times 5/100 = \pi/30 \doteq 0.10472$$ If you use the exact difference you get
$$\Delta V_{exact} = V(0.55) - V(0.5) \doteq 0.10996.$$ So, the approximation is not very accurate in this case, but depending on what you want to do, an approximation of 0.105 may be OK compared with the exact 0.110. Note, however, that the approximation would be much better if we had a smaller ##\Delta r##, say 0.01 instead of 0.05.
Likes opus
Ok thanks guys. So are we just using the fact that at some point, if we have the tangent line at that point and shift the x just a little bit, then that will give us an approximate value of what the function is? And to get an exact difference we would have to evaluate at each x value and then subtract them?
I thought that was exactly what post #11 said explicitly, and other posts hinted at it.
Likes opus
I don't really understand the notation so I put it in English. Most threads I make people tend to not like me restating what they've said but the reason I do it is to see if I can explain it on my own without looking and see if I get it right. Apologies if it seems unnecessary. Thanks for the help everyone.
Related to A different related rates problem - no time mentioned
1. What is a related rates problem?
A related rates problem is a type of mathematical problem that involves finding the rate at which one quantity changes in relation to another quantity. This type of problem often involves multiple variables and the use of calculus to solve.
2. How is a related rates problem different from a regular rate problem?
A related rates problem is different from a regular rate problem because it involves the rates of change of multiple variables. In a regular rate problem, there is typically only one variable and its rate of change is known.
3. Why is time not mentioned in this particular related rates problem?
The absence of time in a related rates problem does not affect the approach to solving it. Time is often not mentioned in related rates problems because it is assumed that the rates of change are happening simultaneously.
4. How do I know which variables to focus on in a related rates problem?
In a related rates problem, it is important to identify the variables that are changing and the variables that are constant. The changing variables will be the ones that are related to each other through a rate of change.
5. What are some real-life examples of related rates problems?
Real-life examples of related rates problems include calculating the rate at which water is flowing out of a faucet or the rate at which the radius of a balloon is changing as it is being inflated. Other examples can include finding the rate at which the distance between two moving objects is changing or the rate at which the angle of elevation of a kite is changing as it flies in the sky.
