A different take on the hollow vs solid rod
  • Thread starter jgscott987
  • Tags
    Rod Solid
In summary: Check that calculation again. The weight is higher, too.The way to think about it is that if I bend a rod, I am placing one side under tension and the opposite side under compression. Somewhere in between, there is a line where the material is neither under tension or compression. I can therefore remove this material without affecting the strength - I've now turned a rod into a tube, which is pound-for-pound stronger than a rod.Can you repeat this for an already slightly hollowed rod though? A hollowed rod will now have boundary conditions on its normal surfaces inside, so bending a hollow rod will then compress the upper surfaces of the outside and inside parts. So I don
jgscott987
I understand the fact that a solid rod is stronger than a hollow rod given the same diameter. My question is whether this fact takes into account the weight of the rod itself.
Imagine two 20 foot long 1/2" diameter steel rods- one is solid and the other is hollow. Support these two rods at either end. Which rod deflects more under its own weight? Which rod deflects more with a 10 lb load hanging from its center?
My instinct is that the additional weight of the solid rod overcomes it's inherently greater rigidity. The hollow rod should deflect less than the solid rod in this scenario.
Any thoughts? I don't know the formulas or software to calculate this, it's just something that I was pondering as I fell asleep last night.
Thanks!
Hi jgscott987, welcome to PF. For the case of a cantilevered rod deforming under its own weight, your instinct is correct. You can prove this to yourself with the http://www.engineersedge.com/beam_bending/beam_bending8.htm" for a hollow beam.
I'll leave it to you to work out the answer for the case of a single attached load.
I can't even find the MoI or the MoE for a steel rod. I'm just satisfied that I am correct! :)
Thanks for your reply.
Thanks!
The moment of inertia term appears in the denominator of the deflection equation for a cantilevered beam under its own weight and with a point load. Hence, for a given radius the deflection will always be less for a solid rod since its moment of inertia is higher.
CS
CS
If you hold the OD constant and then equate the max deflections of the hollow tube to the solid tube you can come up with a relation between the size of ID required and the loads. If I did my algebra correctly I come with:
[tex]d_i^4 = d_o^4\left[1-\frac{P_2}{P_1}\right] [/tex]
A hollowed rod will now have boundary conditions on its normal surfaces inside, so bending a hollow rod will then compress the upper surfaces of the outside and inside parts. So I don't see your (very interesting) argument can be applied to more than a very thin amount of rod down the centre.
This is very interesting- I just wish I could add something to the subject. Maybe I'll go pick up some tubes/rods from the hardware store this weekend.
Yes, but then it requires a quantitative argument. You need to think about how much strength has been removed in light of how much material has been removed. You can do this, of course, but it doesn't have quite the same intuitive appeal.
So you guys really are going to make me go to the hardware store this weekend... :)
I'll post pictures if I find anything interesting.
I did some quick calcs with a cantelever steel beam accounting for the weight (assuming all the weight is concentrated at the end, should yield same basic result though...)
OD .1m, ID .08m
The answer I got was yes & no...
The solid beam deflects more under its own weight across the board. However, when loaded, the solid beam deflects less to a point then they cross and the hollow beam deflects less.
So, for practical applications, Solid beams are better for short beam lengths while hollow beams are better for long beam lengths. I'd be interested to see the results of your project turned out jgscott987.
-Matt
FAQ: A different take on the hollow vs solid rod
1. What is the difference between a hollow and solid rod?
A hollow rod is a cylindrical object with an empty space inside, while a solid rod is a cylindrical object made of a single material throughout with no empty space inside.
2. What are the advantages of using a hollow rod instead of a solid rod?
A hollow rod is typically lighter in weight and more cost-effective to produce. It also has a higher strength-to-weight ratio, making it a better choice for applications where weight is a concern.
3. How does the structural integrity of a hollow rod compare to that of a solid rod?
In general, a solid rod has better structural integrity and can withstand higher loads and stresses compared to a hollow rod. However, the design and material used for the hollow rod can also affect its strength and durability.
4. Are there any specific industries or applications where a hollow rod is more commonly used?
Hollow rods are commonly used in industries such as aerospace, automotive, and construction. They are also commonly used in applications where weight is a concern, such as in sports equipment and musical instruments.
5. Can a hollow rod be made as strong as a solid rod?
Yes, with proper design and material selection, a hollow rod can be made to have the same strength as a solid rod. This can be achieved through techniques such as using thicker walls or reinforcing the hollow space with internal structures.
