A doubt on the fundamental unit of charge
In summary, the existence of charged particles called quarks does not change the fact that charge is quantized, with the basic unit being e/3 instead of e. This means that a charge smaller than e has not been found, as all elementary particles have an electric charge that is a multiple of e/3. This also implies that isolated quarks do not exist and always come in combinations that add up to a multiple of e.
Rishabh Narula
61
"a charge smaller than e has not been found.
if one determines the amount of charge on any charged body like a
charged sphere or charged drop) or any charged particle
(like positron, a-particle)
or any ion, then its charge is always found to be an integral multiple of e,
i.e., e,3e; 4e,...
No Charge will be fractional multiple of e like 0.7e or 2.5e."
the book(notes actually) also gave this side note-
"The existence of charged particles called,quarks
whose electric charges come in multiples of e/3,
would not alter the fact that charge is quantized-
it would merely reduce the size of the basic
unit from e to e/3"
my question is wouldn't that still imply then
that a charge smaller than e does exist since
charge of quarks comes in multiples of e/3.
it would make sense if you add something more
like an isolated quark doesn't exist
like they always come in triplets
or of that sort such that the sum of charges
always adds up to e anyways.am i getting
it right.do correct if wrong.
i.e., e,3e; 4e,...
unit from e to e/3"
my question is wouldn't that still imply then that a charge smaller than e does exist since
it would make sense if you add something more like an isolated quark doesn't exist
like they always come in triplets or of that sort such that the sum of charges
always adds up to e anyways.am i getting it right.do correct if wrong.
I'm not sure which book it is. From what you stated, it appears the author of the book does not know what the charge on a quark is, but is stating that if quarks have a fractional charge, they will still be quantized.
Like you couldn't split a proton and get 1 over sqrt(2) as one of the "pieces".
For "regular" particles, we have only encountered integer multiples of e.
Likes ohwilleke
All elementary particles have an electric charge that is a multiple of e/3.
All particles (elementary or composite) that can exist freely have an electric charge that is a multiple of e, as quarks always come in combinations that add up to a multiple of e.
Likes ohwilleke, vanhees71 and scottdave
Proton have 2 up quarks (charges at 2/3e) and one down quark (charge at -1/3e). Neutrons have one up and two down quarks. Mesons have various combinations, such as a quark plus anti-quark of the same kind.
Likes ohwilleke
FAQ: A doubt on the fundamental unit of charge
What is the fundamental unit of charge?
The fundamental unit of charge is the basic unit of electric charge, denoted by the symbol 'e'. It is the charge of a single proton or electron, and has a value of approximately 1.602 x 10^-19 coulombs.
How was the fundamental unit of charge determined?
The fundamental unit of charge was first determined by the scientist Robert Millikan in 1909 through his famous oil drop experiment. He measured the charge of individual oil droplets and found that they were all multiples of a single, fundamental unit of charge.
Is the fundamental unit of charge constant?
Yes, the fundamental unit of charge is considered to be a constant value. It is a fundamental physical constant and is not dependent on any external factors.
Can the fundamental unit of charge be changed?
No, the fundamental unit of charge cannot be changed. It is a fundamental property of matter and cannot be altered or manipulated.
Why is the fundamental unit of charge important?
The fundamental unit of charge is important because it is the basis for all electrical phenomena in the universe. It helps us understand and quantify the behavior of electrically charged particles and is essential in fields such as electromagnetism and electronics.
