B A doubt regarding vectors, scalars and their role in physics
The discussion centers on the classification of physical quantities as vectors or scalars and the reliability of operations involving them. It is noted that there are no guarantees that all measured quantities can be categorized this way, as these classifications are based on axioms and postulates that are tested experimentally. An example is provided where the mass of a hydrogen atom does not equal the sum of its constituent proton and electron masses in relativistic mechanics. Scalars and vectors are described as zero- and first-order tensors, respectively, with higher-order tensors also being relevant in physics and engineering. The conversation concludes with an acknowledgment of the complexities involved in these classifications.
JackFyre
TL;DR Summary
I have a doubt regarding the basic function of vectors and scalars in physics-
What is the guarantee that every quantity(measured) in physics can be classified as either a vector or a scalar, and that while performing operations on said quantities, they will obey the already established rules of vector/scalar operations?
zero... zero guarantees... It just seems to do quite alright considering what we've achieved by using them. What do you suggest as alternative?
JackFyre said:
Summary:: A doubt regarding vectors, scalars and their role in physics
Can you be more precise about your question?
It's generally implied in classical physics that if we have two particles of mass ##m_1## and ##m_2## and we put them together, then we have a system of mass ##m = m_1 + m_2##.
There's no guarantee that will be correct. It's more an axiom or postulate of classical mechanics that gets tested (along with all the other axioms, postulates or laws of motion) during an experiment.
And, in fact, in relativistic mechanics if ##m## above represents rest mass, then it's not true. For example, if ##m_e## is the mass of an electron and ##m_p## the mass of a proton, and ##m## is the mass of a hydrogen atom with one proton and one electron, then: ##m \ne m_p + m_e##.
That pretty much answers it, thanks!
Scalars and vectors are just zero- and first order tensors, respectively. In physics and engineering we also need to employ higher order tensors, such as the stress tensor.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
