A few homework problems (due Friday)
In summary: The Attempt at a Solution:In summary, the homework problems are worth 30% of our grade and I've done all of them except for these two. I'm thinking about proving either A disunion B ≠ A disunion C) or (A union B ≠ A union C) equivalent to B ≠ C by contradiction.
Jamin2112
986
Disclaimer: This is a college course of mine in which the homework is scrutinized by the professor and worth 30% of our grade. I've done all the homework problems by myself except these 2. Do not, in any way, tell me how to do it. It's okay to explain something that my attempt shows I'm fuzzy on, or to remind me of a certain fact of math reasoning that could lead me in the right direction. Just be wary. Here is a link to the assignment, just in case my writing transcript doesn't do it justice: http://www.math.washington.edu/~folland/hw4.pdf
(I don't know how to make all the fancy symbols)
(A disunion B = A disunion C) and (A union B = A union C) equivalent to B = C
I'm thinking proof by contradiction
(A disunion B ≠ A disunion C) or (A union B ≠ A union C) equivalent to B ≠ C
It seems like common sense but I can't figure out how to explain it. "Pictures are not proofs," my professor says. I mean, obviously if the intersection of A and B is equal to the intersection of B and C then B=C, right?
Help me get on the right track here.
Suppose that A is a subset of Z (integers). Write the following statements entirely in symbols using the quantifiers A (an upside down A) and E (a backwards E). Write out the negative of this statement in symbols.
There is a greatest number in the set A.
Give an example of a set A for which this statement is true. Give another example for which it is false.
The upside down A means "for each" and the backwards E means "there exists a". Just in case you didn't know.
So...
The part that has me stuck is the "There is a greatest number...". I can't figure out how that would be written in symbols. It would come in the predicate, no doubt. Something like {.... : ak > ak+1 }. Nothing in the book speaks of writing a proof for "there is a greatest number". I'm even sure I understand what that means. Does it mean we have a set that goes something like 1,2,3,...,n and n is the greatest number? If so, what sort of predicate says that?
I'm not clear on what you mean by "disunion". I am going to assume you might mean simply [itex]A\cap B[/itex], the intersection, but it also occurred to me that you might mean the "symmetric difference", A\B, the set of all members of A that are NOT in B.
To prove "X equivalent to Y", first prove "if X then Y" and prove "if Y then X".
To prove "A= B" where A and B are sets, first prove "[itex]A\subset B[/itex]", then prove "[itex]B\subset A[/itex]".
To prove "[itex]A\subset B[/itex]" start "if x is in A" and use whatever properties you know of A and B to show "then x is in B".
To prove "A disunion B = A disunion C) and (A union B = A union C) equivalent to B = C" first prove "if A disunion B = A disunion C) and (A union B = A union C) then B = C"
To prove that, basically, you want to use "A disunion B = A disunion C) and (A union B = A union C)" to prove B= C so you start by saying "if x is in B". Now what can you say about x that will lead to proving it is in C? Knowing that x is in B tells you that it is in [itex]A\cup B[/itex] and then because you know [itex]A\cup B= A\cup C[/itex], it follows that x is in [itex]A\cup C[/itex]. From that, either x is in C or it is in A.
If it is in C we are done, so focus on the case that it is in A. If x is in A, since we already know it is in B, x is in [itex]A\cap B[/itex] and we know that [itex]A\cap B= A\cap C[/itex], we know that x is in [itex]A\cap C[/itex]. But any member of [itex]A\cap C[/itex] is in C so either way we know that x is in C.
For the second problem: If x is the greatest member of A, what is the relationship between x and any other member y of A? Does that relationship capture everything about "being the greatest member of A", or is there more to it?
FAQ: A few homework problems (due Friday)
1. What is the purpose of assigning homework problems?
The purpose of assigning homework problems is to reinforce and apply the concepts and skills learned in class. It also helps students practice and improve their problem-solving abilities.
2. How many homework problems should be assigned?
The number of homework problems assigned can vary depending on the difficulty level and the amount of time available. However, a good rule of thumb is to assign enough problems to thoroughly cover the material but not overwhelm the students.
3. Should students be allowed to work together on homework problems?
This is ultimately up to the individual instructor, but it can be beneficial for students to discuss and collaborate on homework problems. However, it's important to ensure that each student is still responsible for understanding and completing the problems on their own.
4. How should homework problems be graded?
There are several different ways to grade homework problems, such as giving a percentage for completion or assigning points for each problem. Some instructors may also choose to provide feedback and not assign a numerical grade. It's important to communicate the grading method clearly to the students.
5. What should students do if they are struggling with a homework problem?
If a student is struggling with a homework problem, they can reach out to the instructor for clarification or guidance. They can also seek help from classmates or utilize resources such as textbooks or online tutorials. It's important for students to actively seek assistance rather than giving up on the problem.
