A few more problems [equilibrium, torque, &c]
In summary, the conversation discusses various physics problems and their solutions. The first problem involves calculating the weight and equilibrium direction of a rod attached to a circular disc with an object suspended from it. The second problem involves calculating the forces exerted by two people carrying a crate up stairs. The third problem involves determining the optimal position for a cable supporting a heavy girder. The experts provide helpful hints and clarify concepts such as torque and position vectors.
a_lawson_2k
39
Hi, got stumped again, but the sooner I figure out how to do these, the easier the others will be in the future.
11-59 said:
A circular disc 0.5m in diameter pivoted about a horizontal axis through its center, has a cord wrapped around its rim. The cord passed over a frictionless pulley P and is attached to an object weighing 240N. Uniform rod 2m long is fastened to the disc, with one end at the center of the disc. The apparatus is in equilibrium, with the rod horizontal
a) what is the weight of the rod?
b) what is the new equilibrium direction of the rod when a second object weighing 20N is suspended from the other end, as http://img159.imageshack.us/img159/5170/1159ij7.gif" ? (what angle does it make with the horizontal?)
for the 240N weight
[tex]\SigmaF_x=0=T-240N[/tex]
so we know what the tension is for the rope. for the large pulley, going clockwise:
[tex]\Sigma\Tau=0=(0.25m)(240N)-(1)(W)[/tex] so the weight was pretty simple to calculate (60N)
The second part is where complications arose; the second equation became:
[tex]\Sigma\Tau=0=(0.25m)(240N)-(1)(60N)(cos(\theta))-(2)(20n)(cos(\theta))[/tex]
I solved for theta and got 55.7 degrees, the book said 53.2...
For a separate problem, I need clarification about what the definitions for slipping and tipping are in the context of equilibrium, and I'm pretty sure I can take it from there.
11-61 said:
Two people are carrying a 200kg crate up a flight of stairs; the crate is 1,25m long and 0.5m high, and its center of gravity is at its geometric center. The stairs make a 45 degree angle with the floor, and the crate is carried at a 45 degree angle so that it is parallel with the stairs. If the force from each person is vertical, what is the magnitude of each of the forces? http://img109.imageshack.us/img109/5865/1961cp8.gif"
I got as far as [tex]\SigmaF_x=0=F_1+F_2-1960N[/tex]
two variables, the equation for torque (counterclockwise) about the center of mass should handle this:
[tex]\Sigma\Tau=0=(P_2)x(F_2)-(P_1)x(F_1)=F_2\frac{\sqrt{2}}{2}-F_1\frac{\sqrt{2}}{4}[/tex]
This doesn't get the results I need (1370N for F1 and 590N), so I think I'm computing the torque wrong, since the answers both add to 1960 (thank goodness!)
11-83 said:
Heavy horizontal girder of length L has several objects suspended from it, it is supported by a tensionless pivot at its left end and a cable of negligible weight attached to an I-beam at a point distance h directly above the girder's center. Where should the other end be placed to minimize tension of the cable? HINT: remember to the maximum distance from pivot to the end of the beam is L. http://img171.imageshack.us/img171/9053/1983kl9.gif"
I labeled the tension, natural force exerted from the pivot, and weight of the beam.
[tex]\Sigma\F_x=n-Tcos(\theta), \Sigma\F_y=Tsin(\theta)-w[/tex]
Since the girder can't accelerate in the X direction, the point cannot be closer to the pivot on the girder than L/2.
From there, the torque about the pivot would be
[tex]\Sigma\Tau=(\lambda+\frac{L}{2})T* arctan(\frac{\lambda}{h})-\frac{L}{2}W[/tex]
The answer was L/2+h^2/L, and I couldn't get to that answer. Not sure how to go from here...
Thanks again for the help
problem 11-59
a_lawson_2k said:
for the 240N weight
Your method and final equation are correct. Redo your calculation.
problem 11-61
I don't understand how you are calculating the torques. How did you determine the distance from the center of mass to the lines of the two vertical forces? (Note that they are lifting at the bottom of the crate, while the center of mass is in the middle of the crate.)
I found the position vectors relative to the center of mass for each point of contact for each force and took the cross products. That's how I did it before and I got the right answer, not sure why it doesn't work now.
Must have been a typo on my calculator; thanks.
That's a good approach. What did you get for the position vectors and the angles they make with the applied forces?
I got [tex](\frac{-1}{4}, \frac{-1}{2})\sqrt{2})[/tex] and [tex](\frac{1}{2}, \frac{1}{4})\sqrt{2})[/tex]. I got them by adding and subtracting half of the position vector of the bottom edge (3/4 sqrt(2) for both i and j) by the position of the midpoint on the bottom edge (1/8, -1/8)sqrt(2). I re-did the calculation on Maple just to double-check myself, and got the same vectors. As for the angles, I didn't take that into consideration, as the cross-product alone is the definition of the torque.
Here's what I'd do. I'd use a coordinate system with the center of the crate at the origin and the x-axis parallel to the bottom of the crate. Given that, I get the following position vectors:
r_1 = (-.25, -.625)
r_2 = (-.25, +.625)
And the following force vectors:
[tex] \vec{F}_1 = (\sqrt{2}/2, \sqrt{2}/2) F_1[/tex]
[tex] \vec{F}_2 = (\sqrt{2}/2, \sqrt{2}/2) F_2[/tex]
That did it, not sure exactly why my previous system was flawed though, careless error perhaps?
I still need some help with the last one and the one about the definitions for slipping and tipping are in the context of equilibrium. Thanks
problem 11-83
The pivot point is free to exert force, as needed, in both the x and y directions. Also, what do you mean by "natural" force? I'm not familiar with that term. (Is it the same as "normal" force?)
Two problems:
(1) Arctan is just the angle, I presume you mean the sine of that angle.
(2) Why assume that the weight is in the middle? The problem states that all sorts of things are hanging from the girder, so who knows where the net weight acts?
I'd say that that answer is not quite right, but close to what I get. In any case, rewrite your torque equation in terms of [itex]\lambda[/itex], L, and h. (What's the net torque equal? What's constant?) Then solve for the value of [itex]\lambda[/itex] that will minimize the tension. Hint: Find an expression and take its derivitive.
Why don't you post that problem so we have a context for your questions?
"Slipping" is the sliding of two surfaces against each other. Often a problem will ask for some condition that will just barely prevent slipping--meaning that the force of static friction preventing slipping is at its maximum value.
"Tipping" often means that some applied force creates enough torque to tip something over (about its bottom edge, perhaps)--meaning that the applied torque must overcome any torque in the opposite direction, often from the weight of the object.
Two problems:
I fixed that, using the cosine, and it worked. It must have been an input oversight on my part.
A conveyor system for loading bales which are 0.5m high, 0.25m wide, 0.80m long, mass 30kg, coefficient of static friction between the bale and the conveyor is 0.6, and the system moves with constant speed. What angle [tex]\beta[/tex] between the horizontal and the belt would cause the bale to slip and tip?
What would the angles be if the coefficient was 0.4?
For slipping, when [tex]\Sigma F_x=0[/tex], I got 31 and 22 degrees, in line with the book's solutions, so I can't be too far off.
Good, so it looks like you understand slipping. As for tipping, figure out what angle of incline would make the weight--acting through the center of mass--fall outside the base of the bale. (This angle will depend on the orientation of the bale on the conveyer.)
Related to A few more problems [equilibrium, torque, &c]
1. What is equilibrium and how does it relate to science?
Equilibrium is a state where all forces acting on an object are balanced and there is no net force or acceleration. In science, equilibrium is an important concept in understanding the behavior of objects in various systems, such as physics, chemistry, and biology.
2. How do you calculate torque?
Torque is the measure of the force that causes an object to rotate. It is calculated by multiplying the force applied by the distance from the pivot point, or fulcrum, to the point where the force is applied. The unit of torque is Newton-meters (Nm) in the metric system and foot-pounds (ft-lb) in the imperial system.
3. What is the difference between static and dynamic equilibrium?
Static equilibrium is when an object is at rest and all forces are balanced, while dynamic equilibrium is when the object is moving at a constant velocity with all forces still balanced. In other words, static equilibrium deals with stationary objects and dynamic equilibrium deals with moving objects.
4. How does torque affect rotational motion?
Torque plays a crucial role in rotational motion as it is the force that causes an object to rotate. The greater the torque, the faster the object will rotate. In addition, the direction of the torque determines the direction of the rotation.
5. What are some real-life examples of equilibrium and torque?
Some common examples of equilibrium include a see-saw at rest, a book sitting on a table, and a person standing still on the ground. Examples of torque in everyday life include opening a door, using a wrench to tighten a bolt, and throwing a ball. In all of these examples, torque is required to cause rotational motion.
