A few queries on the variation of parameters method
In summary, the technique of variation of parameters involves writing the particular solution to an inhomogeneous ODE in the form of u_1y_1+u_2y_2, where u_1 and u_2 are arbitrary functions. This is not because the particular solution is assumed to be similar to the complementary solution, but because this form allows for easy differentiation and solving of the homogeneous part of the equation. The remaining terms can then be used to find a solution to the inhomogeneous part. By adding constraints, such as u_1'y_1+u_2'y_2=0, we can determine specific forms for the arbitrary functions and find a particular solution to the ODE. This method can be
"Don't panic!"
601
I've been reviewing my knowledge on the technique of variation of parameters to solve differential equations and have a couple of queries that I'd like to clear up (particularly for 2nd order inhomogeneous ODEs), if possible.
The first is that, given the complementary solution, [itex]y_{c}(x)=c_{1}y_{1}(x)+c_{2}y_{2}(x)[/itex], to some 2nd-order inhomogeneous ODE: $$a_{2}(x)y''(x)+a_{1}(x)y'(x)+a_{0}(x)y(x)=f(x)$$ we assume that the particular solution $y_{p}(x)$ has the form $$y_{p}(x)=u_{1}(x)y_{1}(x)+u_{2}(x)y_{2}(x)$$ where [itex]u_{1}(x)[/itex] and [itex]u_{2}(x)[/itex] are arbitrary functions.
Is the motivation for this ansatz that the homogeneous equation can be viewed as a special case of the inhomogeneous one, i.e. with [itex]f(x)=0[/itex], and as such it is reasonable to assume that the particular solution to the inhomogeneous equation will be of a similar form to the complementary solution?!
The second is that, starting from this ansatz we note that we require that [itex]y_{p}[/itex] is a solution to the inhomogeneous equation, and upon inserting this into the ODE (and doing a little algebra), this leaves us with the equation $$a_{2}\frac{d}{dx}\left[u'_{1}y_{1}+u'_{2}y_{2}\right]+a_{1}\left[u'_{1}y_{1}+u'_{2}y_{2}\right]+ a_{2}\left[u'_{1}y'_{1}+u'_{2}y'_{2}\right]= f(x)$$ which applies a single constraint on the forms of [itex]u_{1}(x)[/itex] and [itex]u_{2}(x)[/itex]. However, in order to find solutions for both [itex]u_{1}(x)[/itex] and [itex]u_{2}(x)[/itex] we require two equations (just a single equation would enable us to find a solution of one in terms of the other, but this other function is still arbitrary and thus we need a further equation to determine its form [I'm a bit unsure whether my argument is correct here?!]). As such, we have one constraint (that the LHS equals the RHS [which has a fixed form [itex]f(x)[/itex]]), and this leaves us with one degree of freedom that we are free to constrain. Thus, we choose that $$u'_{1}(x)y_{1}(x)+u'_{2}(x)y_{2}(x)=0$$ such that $$\left[u'_{1}(x)y'_{1}(x)+u'_{2}(x)y'_{2}(x)\right]= \frac{f(x)}{a_{2}(x)}$$ Is this the correct reasoning?
Given two functions, [itex]y_1[/itex] and [itex]y_2[/itex]. Any function can be written in the form "[itex]u_1y_1+ u_2y_2[/itex]" for some functions [itex]u_1[/itex] an [itex]u_2[/itex] so, no, we do not "assume that the particular solution to the inhomogeneous equation will be of a similar form to the complementary solution". The point is simply that, by the product rule, some parts of a derivative of [itex]u_1y_1+ u_2y_2[itex] will have only the "y"s differentiated so that the "u"s are treated like constants and that part will be 0 because the "y"s satisfy the homogeneous equation. So we never have an equation involving the "u"s without any differentiation. Further, because there are an infinite number of ways to write a solution to the entire equation in that way, we can add additional requirements, such as "[tex]u_1'y_1+ u_2'y_2= 0[/tex] so that we never have higher derivatives- we will always end with equations involving only the first order derivatives of the "u"s. If we have an nth order equation, this will always result in n equations for the first derivatives. We can solve for [itex]u_1'[/itex] and [itex]u_2'[/itex] and then integrate to find [itex]u_1[/itex] and [itex]u_2[/itex]
HallsofIvy said:
Given two functions, y1y_1 and y2y_2. Any function can be written in the form "u1y1+u2y2u_1y_1+ u_2y_2" for some functions u1u_1 an u2u_2 so, no, we do not "assume that the particular solution to the inhomogeneous equation will be of a similar form to the complementary solution"
So is there any particular motivation behind this ansatz at all then, or just that, when differentiated, it can solve the homogeneous part of the equation and still has terms remaining that can be used to find a solution to the inhomogeneous part?
So, in general, if one has an nth order equation then we seek a solution containing n arbitrary functions with the constraint that they satisfy the original ODE. Then, this would, in principle, provide us with an infinite number of particular solutions, however, we only need to find one particular solution. As such, in order to find a particular solution, as n-1 of the functions remain arbitrary (the nth being determined by the condition that the overall function is a solution to the ODE), we may apply n-1 constraints to determine particular forms for these functions. We are free to choose whatever constraint we like and so the easiest is one that keeps the equations to first order in derivatives, resulting in the constraint [itex]u'_{1}y_{1}+u'_{2}y_{2}=0[/itex] (for the 2nd order case). This then enables us to solve for the n arbitrary functions and find specific forms for them and thus enabling us to specify a particular solution to the original ODE. Would this be correct?
Related to A few queries on the variation of parameters method
1. What is the variation of parameters method used for?
The variation of parameters method is a mathematical technique used to solve certain types of differential equations. It is particularly useful for solving non-homogenous linear differential equations.
2. How does the variation of parameters method work?
The variation of parameters method involves finding a particular solution to a non-homogenous linear differential equation by replacing the constants in the general solution with functions. These functions are then determined by substituting them into the differential equation and solving for their coefficients.
3. What are the advantages of using the variation of parameters method?
One advantage of the variation of parameters method is that it can be applied to a wide range of differential equations, including those with variable coefficients. It also allows for the use of initial or boundary conditions to find specific solutions.
4. What are the limitations of the variation of parameters method?
The variation of parameters method is not always applicable, as it can only be used for non-homogenous linear differential equations. It can also be a time-consuming and complex method, requiring multiple steps and calculations.
5. Are there any real-world applications of the variation of parameters method?
Yes, the variation of parameters method has many applications in physics, engineering, and other fields that involve differential equations. It can be used to model systems such as electrical circuits, population growth, and chemical reactions.
