A few questions about charged particles
In summary: Magnetic fields from different sources do not really interact with each other - the magnetic fields just add up.
Samson4
245
I understand the basic forces moving charges experience in magnetic fields. I dont; however, understand how these these charges would interact with particles uninfluenced by the magnetic field.
1. If a charged particle is moving perpendicular to a uniform magnetic field, it will follow a circular path. Does the particles motion create a magnetic field that interacts with magnetic field that is applying a force to it? For example, will the magnetic field strength inside the circular path be at a higher density than outside the path of the particle?
2. If an electron is moving in a circular path in a magnetic field, experiencing a lorentz force. But, just inside it's circular path, the magnetic field strength falls off to zero. A positive particle with a velocity perpendicular to this path, originating from the center of the circle, is uninfluenced by the magnetic field. How will the electron and positive particle interact in the area before the positive charge enters the magnetic field?
3. How do oppositely charged particles influence each other if they are moving perpendicular to each other? Is it purely attraction or are their complex magnetic interactions that explain their movements. What terms can I search to research this interaction?
Magnetic fields from different sources do not really interact with each other - the magnetic fields just add up. Yes, a particle moving in a circle will change the magnetic field (a tiny bit).
Or does it get weaker? You can calculate it to check.
Perpendicular to a circle? So along the magnetic field lines outside?
In the same way they would without magnetic field.
It can get complicated.
You can always take the Maxwell equation and calculate the electric and magnetic field everywhere. Retarded potentials can be useful as well.
Likes Samson4
No, the positive particles are originating in the center of the electron's circular path, moving perpendicular to the electron.
This interaction would be purely electric? I thought it would have a cycloid type motion because of a lorrentz force due to a magnetic field acompaning the electrons circular path.
In general, if anything is moving relative to whatever you want to consider, magnetic fields have some influence. Their contribution relative to the electric fields scales with v/c with the velocity v and the speed of light c, so for nonrelativistic particles they are often negligible.
Likes Samson4
Related to A few questions about charged particles
1. What are charged particles?
Charged particles are subatomic particles that have an electric charge. This charge can be either positive or negative, and it is determined by the number of protons and electrons in the particle.
2. How do charged particles interact with each other?
Charged particles interact with each other through electromagnetic forces. Like charges repel each other, while opposite charges attract each other.
3. What is the significance of charged particles in science?
Charged particles play a crucial role in many scientific fields, including physics, chemistry, and biology. They are responsible for electricity, magnetism, and chemical reactions, among other important phenomena.
4. How are charged particles created?
Charged particles can be created through various processes, such as radioactive decay, chemical reactions, and the collision of high-energy particles. They can also be artificially created in particle accelerators.
5. What are some examples of charged particles?
Some examples of charged particles include protons, electrons, and ions (atoms or molecules with a net electric charge). These particles are essential building blocks of matter and are present in all atoms and molecules.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
