A few questions about perturbation and string theory
In summary, the conversation discusses the concept of finiteness in string theory and how it differs from point particle perturbation theory. It is suggested that the stringy nature of objects in string theory implies that contributions at any order should be finite. However, there is a criticism that the sum of all contributions at each order in string theory is not "Borel summable," which has led to the search for a non-perturbative formulation of string theory. It is also mentioned that while there is a proof of finiteness to the first order, there is currently no proof beyond that. The conversation also touches on the concept of renormalization in quantum field theory and the potential for new divergences in higher orders. Overall
QuantumKitty
Am I correct in thinking string theory has an infinite number of terms so to prove finiteness to the first order means proving one (or the first) term to be finite?
If so, then how can we ever prove an infinite number of terms? And what exactly does it mean to say, or prove, something is finite to the first (or second, or third, etc..) approximation? What about it is finite? And what makes up one term?
Please try not to be too technical with your answers or I will be lost and have even more questions...I'm just a curious layman.
I lost the previous attempted post, so I'll be even more brief. I don't know if this is answering your questions, but I'm trying. In perturbative expansions of a quantum amplitude, you can't check term by term since it never ends. "Finite to n-th order" means that none of the 1st, 2nd,..,n-th order contributions are individually infinite (and therefore that the sum of those contributions is a finite result). In perturbative string theory, one can show that the stringy nature of the objects implies that the contributions to any order should be finite, unlike in point particle perturbation theory in which there are point-like interactions. Hence the claim that the amplitudes in string theory are finite at all orders. HOWEVER, what about the sum of all those contributions at each order? That's the business of the analysis of infinite series, and in perturbative string theory they aren't "Borel summable", which means the series diverge in a certain way that one is used to requiring in point particle perturbation theory to get physical probability amplitudes. That's a big criticism and inspired the searches for a non-perturbative formulation of string theory, in which infinite expansions are fundamentall not involved.
javierR said:
... In perturbative string theory, one can show that the stringy nature of the objects implies that the contributions to any order should be finite, unlike in point particle perturbation theory ... Hence the claim that the amplitudes in string theory are finite at all orders.
As far as I know no such proof (beyond first order) has been published up to now!
In QFT infinities arise in amplitudes containing closed loops. They have to be renormalized which means that a subtraction scheme has to be applied which removes infinities and "hides" them in unphysical parameters (e.g. charge, coupling constant etc.). For renormalizable theories one can derive identities relating amplitudes of different orders from which one can deduce that no new types of divergencies appear in higher orders (see e.g. power-counting, BPHZ scheme). From this one can further deduced that new divergencies in higher orders can be renormalized via the same subtractions, which means that it is sufficient to "hide" the divergent contributions in the same unphysical parameters as above.
In string theory the subtraction of infinities should not be required, but nevertheless there must be a relation between different amplitudes which allows to prove finiteness to all orders.
I do not know if such relations between amplitudes of different orders exist.
FAQ: A few questions about perturbation and string theory
What is perturbation theory?
Perturbation theory is a mathematical method used in physics to approximate solutions to complex problems by breaking them down into simpler, more manageable parts. It is especially useful in studying systems that are difficult to solve using traditional methods.
How does perturbation theory relate to string theory?
Perturbation theory is often used in string theory to study the behavior of strings in curved spacetime. By perturbing the equations that describe the strings, scientists can make predictions about how they will behave in different environments.
What is the difference between first-order and higher-order perturbation theory?
First-order perturbation theory only takes into account the effects of small changes in a system, while higher-order perturbation theory considers more significant changes. In string theory, higher-order perturbation theory is used to study more complex phenomena, such as interactions between strings.
How is perturbation theory used in practical applications?
Perturbation theory has many practical applications in various fields, including quantum mechanics, astrophysics, and fluid dynamics. It is used to make predictions about the behavior of complex systems and to develop mathematical models that can be used to understand real-world phenomena.
What are the limitations of perturbation theory?
Perturbation theory is not always accurate, especially when applied to highly nonlinear systems. It also assumes that any changes in the system are small, which may not always be the case. In these situations, other methods, such as numerical simulations, may be more appropriate.
